My First Evoscans..... What do you guys think?
Old Nov 8, 2006 | 07:18 AM
evo ippo's Avatar
Originally Posted by SophieSleeps
Ok ok. Makes a little more sense.
But again, why an EGT sensor? Having a wideband in there is probably good enough...then you also have the factory EGT readings as well.
i dont know i guess it makes use of the LCD display and it was a package deal with boost sensor, EGT and Wideband
Old Nov 8, 2006 | 12:59 PM
Rob W.'s Avatar
What factory EGT do you refer to? Do you mean the channel labeled "EGR Temp" in Evoscan? If so, has anyone confirmed the accuracy of this equation? Has anyone confirmed good correlation to a real EGT?
Where is this sensor located in the exhaust stream?
Old Nov 8, 2006 | 08:19 PM
evo ippo's Avatar
does anybody know where the best place to put the EGT sensor????
Old Nov 8, 2006 | 09:27 PM
LimPShoT's Avatar
#2 runner a couple inches from the head.
Old Nov 9, 2006 | 07:21 AM
evo ippo's Avatar
this is another post , what do you guys think about the EGT sensor location???? but that is a nice a$$ manifold
Old Nov 9, 2006 | 07:24 AM
evo ippo's Avatar
https://www.evolutionm.net/forums/sh...ght=egt+sensor
Old Nov 9, 2006 | 07:35 AM
evo ippo's Avatar
Old Nov 9, 2006 | 08:14 AM
MalibuJack's Avatar
The EGR sensor is in the recirculation heat crossover, and although the temps are accurate in that formula for that sensor, they do not reflect the Exhaust gas temp your thinking of, which you would use for tuning. This is the temp for an emission device (preheat the intake manifold, and exchange some heat into the intake to improve emissions on cold start) Or at least thats what I was led to believe..
Old Nov 10, 2006 | 06:09 AM
Rob W.'s Avatar
Thanks, Jack. That was exactly what I thought.
It is interesting that on DSM's, it seemed like a very common thing that everyone had an EGT gauge, but on EVO's, it's very rare.
Old Nov 10, 2006 | 06:14 AM
PA-silver03evo's Avatar
I think its mainly because so many people are using wideband 02s now. Back in my dsm days, I didnt know anyone that had a wideband 02. Everyone just had egt gauges and dataloggers to log knock and narrowband 02s.
Old Nov 10, 2006 | 08:23 AM
MalibuJack's Avatar
Widebands have went from being an exotic and expensive tool (before people realized that the sensors were cheap to buy, and the controllers are now cheap to make) to a reasonable price..
If you have no choice, EGT is the second best way to tune with, but it can only tell you your EGT's are really hot, with the regular logging, you would see your knock counts, but unfortunately EGT's can be very hot for two reasons, too rich, or too lean, too rich and its hot because the fuel is still burning, it can be detrimental to your turbo, but might not do any damage do your engine, where running too lean will melt all sorts of stuff in the engine.. The heat is in the combustion chamber.
The best tool to use is a wideband O2 sensor, and an EGT gage.. but EGT only is really something that you have to be cautious with since you only have a narrowband sensor telling you if your rich or lean, but not quite accurate enough to know how rich or lean, which means you have to leave plenty of margin for error..
Old Nov 10, 2006 | 09:33 PM
C6C6CH3vo's Avatar
So lambda sensor + EGT = quantitate and qualitative monitoring
EGT only = qualitative monitoring
OK here's the big laugh, I have niether, and worst - I'm running a 14 month old custom job for mods I had before adding methanol and 10.5 HS.
I basically added timing and pulled fuel up to 0.9 in respective spray areas until knock vanished so I got my wad of clay. Now that I made a surprising forward progress of W/M power shooting from the hip, I have hit a wall.
I now need a way to measure burn and furthermore somehow try to comprehend my fuel map - I don't know if there is any substance to the jagged and beat-up group of numbers called my fuel map after a pre-EcuFlash HKS rs and fuel pump custom flash for it, not to mention my contibution, but without WB, I need it.
  • So whats the WB of choice for just evoscan logging with precision - nothing fancy, just an accurate sensor?
Old Nov 11, 2006 | 05:12 AM
MalibuJack's Avatar
The short answer, is Any of them capable of logging the data you need.
All I can say about your tuning without the instrumentation is a bit like precision shooting with a shotgun.. Sure some of your pellets may hit the target, but most will be nowhere close.. What I mean is, you have to tune very conservatively, but your not 100% sure how conservative your tune really is. So should you have an unexpected problem, you really don't know what sort of safety margin you have.
The honest truth is, people have been tuning by narrowband alone for a long time, and some have gone pretty fast.. But I'd much rather have the instrumentation to tell me If things are good, than be ignorant of it.
EvolutionRacing
Jan 18, 2016 09:55 AM
HermaN
Nov 22, 2009 07:20 PM
Turbo Kyle
Jul 28, 2008 03:30 PM
evil mechanic
Jan 8, 2007 12:36 PM
Ludikraut
Aug 23, 2006 01:37 AM
