JDM Evo IX MAP sensor group buy
Old Nov 23, 2006 | 04:37 PM
  #46
mrfred's Avatar
Originally Posted by nj1266
When I used to log with my pocketlogger I was able to log the stock 1 bar MAP sensor. IIRC, it maxed out @ 17.6 psi. Can Evoscan do the same thing? If so, then count me in. I would love to be able to log boost via Evoscan.
With the JDM Evo IX map sensor, you'll be able log up to 32 psi (maybe more) with Evoscan/Mitsulogger. The only issue is whether the JDM sensor is going to cause the ecu to throw a code. I've still got my car on jackstands for a LICP and HFC, so I haven't tried to start the car yet. I may install the sensor tomorrow and turn on the ignition just to see if the ecu throws a code with the engine off but ignition on.
Old Nov 23, 2006 | 04:45 PM
  #47
nj1266's Avatar
mrfred, add me to your list. If this works, then I will have all the portable logging tools I need.
Old Nov 24, 2006 | 09:44 AM
  #48
marksae's Avatar
I'm in on the group buy.
Old Nov 24, 2006 | 02:50 PM
  #49
mrfred's Avatar
JDM Evo IX map sensor group buy signup
1. MalibuJack
2. chrisw
3. MR. SNOW
4. nothere
5. dudical26
6. nj1266
7. marksae
8.
9.
10.
Old Dec 12, 2006 | 05:18 AM
  #50
o.e.boost's Avatar
so whats the update about the senors?!!!!...it'll be awesome to log boost with such a simple mod if it works!!!
Old Dec 12, 2006 | 08:10 AM
  #51
MalibuJack's Avatar
Since I havent heard anything about this, I decided to experiment with a GM 3 bar sensor and should have some documentation on it by the end of the week.
Buschur sells a special fitting that bolts in place of the stock sensor, so I will try doing that instead. It makes sense in my case because If it works, its one less issue to deal with on my aftermarket intake manifold when I install it.
Old Dec 13, 2006 | 11:37 PM
  #52
mrfred's Avatar
Had to leave town for travel. I'll be back on Dec 20 and will try the JDM sensor as soon as I get back.
Old Dec 13, 2006 | 11:58 PM
  #53
MR. SNOW's Avatar
Jack let us know how this swap of the GM 3bar sensor.
thanks
josh hit me up on pm. thanks again
Old Dec 15, 2006 | 01:05 PM
  #54
High_PSI's Avatar
Yeah I am very interested I would love to have proper boost readings to tune by.
Old Feb 21, 2007 | 09:21 PM
  #55
evo4mad's Avatar
Its been a month since any activity on this thread, are any of the MAP (boost) sensors working well for logging?
Old Feb 22, 2007 | 05:34 AM
  #56
MalibuJack's Avatar
Ive been able to log with a GM 3 bar sensor instead of the stock sensor. Unfortunately you have to disconnect both of the vacuum lines to the EGR valve (and plug them) since they also hook up to several other places. The other problem (On the USDM cars for certain, the others I'm not sure) is you will throw different EGR codes and not complete the EGR Test sucessfully (which would be an inspection/obd-ii issue) So I'm not currently using the sensor. I have to assume that the JDM sensor would work the same way.
So, in order to do this, the ECU would need some modification to not throw those codes or you would have to change the calibration table for EGR function (which I don't know where it is, or if it even exists)
The sensor itself does read through MUT and would only need to use the right calibration. (JDM is easier since the calibration is already known)
Old Feb 23, 2007 | 11:13 AM
  #57
marksae's Avatar
Jack,
Do you have the calibration #s between boost and RAW voltage value for the GM sensor? I'm going to use a GM MAP sensor to log boost and wire it through the stock MAP sensor port. Thanks!
Old Feb 23, 2007 | 01:00 PM
  #58
MalibuJack's Avatar
No I've just verified it works, I have to take a bit of time to match the digital output to boost level as I already have a GM map sensor installed in the car running to my UTEC/ECU+ (whichever I'm testing at the time) so I already know what its reading.
Old Feb 23, 2007 | 01:12 PM
  #59
marksae's Avatar
The GM Map sensor mod through the MAP sensor port mod has the done many times on 2g DSMs and logged w/ DSMLink. I'll shoot the DSMLink guys an email to ask what the calc routine is for the GM sensor.
Old Feb 23, 2007 | 02:20 PM
  #60
kcevo's Avatar
Which 3bar do you have? Part # wise, may be able to help ya get a voltage vs psi table.
