JDM Evo IX MAP sensor group buy
Old Apr 21, 2007 | 12:33 PM
  #196
laakness's Avatar
mrfred, the car idles and runs fine with the jdm sensor in it. I'm going to shower and then take it out for a ride to run some errands.
Here is my log of it idling from cold to full warmup
File Type: zip
Old Apr 21, 2007 | 02:30 PM
  #197
laakness's Avatar
So the car drives just like normal, no issues on a 2003 Evo 8.
It took a while to throw a code but I did throw the following:
P1400 - Manifold Differential Pressure Sensor circuit.
That is pretty obviousl huh
I did some runs up to 22 psi and normal cruising...no issues
Old Apr 21, 2007 | 05:53 PM
  #198
chmodlf's Avatar
Nice fuel trims.
Old Apr 21, 2007 | 05:54 PM
  #199
laakness's Avatar
Oh, heh, thanks. It's an AMS custom with 272's
Old Apr 23, 2007 | 12:24 AM
  #200
fixem2's Avatar
Where you able to log the boost after install?
Old Apr 23, 2007 | 05:11 AM
  #201
laakness's Avatar
I thought you had to modify the ECU tables to allow for values outside the range of the stock sensor. Right now I just get a CEL everytime I boost high. mrfred is looking for the tables to modify.
Old Apr 23, 2007 | 06:15 AM
  #202
fixem2's Avatar
cool. Not sure about the boost range.
Old Apr 23, 2007 | 10:54 AM
  #203
mrfred's Avatar
I think found the tables. I would like to try out the fix on your ROM before I release the tables. Can you email me a zipped copy of your ROM?
Old Apr 23, 2007 | 11:00 AM
  #204
phenem's Avatar
Same issue here mrfred. I have the sensor currently installed and seeing the same issues. I can email you my ROM right now if you need another ROM. I have the 94170014 ROM. PM me your email and I will send it over.
~Zach
Old Apr 23, 2007 | 03:05 PM
  #205
mrfred's Avatar
~Zach
Send it! :-) I'm itching to see if the mods will work.
Old Apr 23, 2007 | 03:28 PM
  #206
phenem's Avatar
Whats your email?
Old Apr 23, 2007 | 03:54 PM
  #207
laakness's Avatar
I sent you a PM mrfred, hit me up with the email. I'm around all night tonight.
Old Apr 23, 2007 | 03:59 PM
  #208
phenem's Avatar
mrfred, I pm'ed you my ROM as well. I will up all night until around 12 AM EST. Let me know if there is anything I can do for testing...
Old Apr 24, 2007 | 07:51 PM
  #209
phenem's Avatar
mrfred, any updates?
Old Apr 24, 2007 | 09:08 PM
  #210
mrfred's Avatar
The Evo 8 tables appear to be quite a bit different than the Evo 9. So I'm waiting to hear from Bez on a few questions. Hopefully, I'll get a reply from him by morning.
