JDM Evo IX MAP sensor group buy
Old Mar 23, 2007 | 11:03 AM
  #136
laakness's Avatar
Thanks Ralph, that is exactly what I meant.
I have a feeling that once this is worked out for the 8's it will be a long line to get one of these so I figure I'll get in while the gettin' is good
Old Mar 23, 2007 | 04:39 PM
  #137
Max Power's Avatar
I want dibs if this works on an 8!!!
Old Mar 23, 2007 | 05:34 PM
  #138
andenbre's Avatar
Originally Posted by mrfred
Ah, ok. :-) That would fit with the PM. Anyhow, I've got 10 of the MAP sensors showing up in about two weeks.
good deal, I have been reading your posts in aktivematrix on the solution for the light
Old Mar 23, 2007 | 05:35 PM
  #139
mrfred's Avatar
Yeah, I hadn't posted that yet here. Got distracted by tuning my BCS. :-)
Old Mar 23, 2007 | 06:06 PM
  #140
phenem's Avatar
JDM Evo IX map sensor group buy signup
1.joedr
2.razorlab x2
3.Andenbre
4.Ralph
5.Laakness
6.Phenem
7.
8.
9.
10.
Count me in!
Old Mar 23, 2007 | 08:00 PM
  #141
Max Power's Avatar
1.joedr
2.razorlab x2
3.Andenbre
4.Ralph
5.Laakness
6.Phenem
7.Max Power
8.
9.
10.
Bah, I'll just take one now - let me know where to send the MO.
Old Mar 23, 2007 | 09:24 PM
  #142
mrfred's Avatar
The sensors will be leaving Japan on Tuesday of next week. Hoping to have them two weeks after that. I'll PM you all for payment after they arrive.
Old Mar 23, 2007 | 10:00 PM
  #143
MalibuJack's Avatar
I managed to sucessfully disable the EGR Monitor/Test so it shows as Unsupported in an OBD-II scanner.. Thats 50% of the battle when it comes to swapping the sensor.
Old Mar 23, 2007 | 10:17 PM
  #144
mrfred's Avatar
I'm not getting any EGR CELs, and I haven't disabled the test. For the Evo 8s, I think its the same situation as the Evo 9; update the MAP sensor translation table with the JDM values so that the sensor can provide the correct pressure data to the EGR system. I think that someone just needs to locate the MAP sensor translation table, and the high/low fault check values in the Evo 8 ROMs.
Now if someone intends to run without EGR (say with an aftermarket manifold), then I can see that it would be useful to shut down the EGR monitor.
Old Mar 24, 2007 | 06:10 AM
  #145
MalibuJack's Avatar
Yep that was my original reason for it. But disabling the EGR test also disabled a few CEL codes associated with it. So it'll never be a problem running an aftermarket or stock 3 bar sensor. You can disable the car's use of the sensor also with another bit, and the MDP/MAP Cel code goes away also, but I left it enabled in the samples I posted as its something I'd want functioning once the table is found and the sensor is calibrated.
Old Mar 25, 2007 | 08:58 PM
  #146
mrfred's Avatar
1.joedr
2.razorlab x2
3.Andenbre
4.Ralph
5.Laakness
6.Phenem
7.Max Power
8.Pd1
9.
I've got 10 coming within three weeks. One not accounted for yet.
Old Mar 25, 2007 | 10:00 PM
  #147
fixem2's Avatar
I am in :
1.joedr
2.razorlab x2
3.Andenbre
4.Ralph
5.Laakness
6.Phenem
7.Max Power
8.Pd1
9.fixem2
Old Mar 27, 2007 | 06:39 AM
  #148
mrfred's Avatar
Originally Posted by fixem2
I am in :
1.joedr
2.razorlab x2
3.Andenbre
4.Ralph
5.Laakness
6.Phenem
7.Max Power
8.Pd1
9.fixem2
Turns out that these 10 JDM sensors are all that were in Japan. There won't be any more available until sometime in May.
If anyone is interested in the next bunch that I bring over, please PM me. And I've got updated install instructions in this thread:
https://www.evolutionm.net/forums/sh...d.php?t=259595
Old Mar 27, 2007 | 09:54 PM
  #149
RazorLab's Avatar
I take it you are going to contact us when this first batch comes in so we can take care of payment, etc?
Old Mar 28, 2007 | 08:46 AM
  #150
mrfred's Avatar
Yep. :-)
