JDM Evo IX MAP sensor group buy
Old Apr 24, 2007 | 10:47 PM
  #211
Pd1's Avatar
Pd1
I've got my JDM MAP installed and it's logging via EvoScan v.99, but I'm pretty sure it's giving me some incorrect data. While my GM 3Bar says I'm boosting 23psi, the JDM MAP says I'm closer to 30psi!
MrFred and I have gone back and forth on this trying to solve the problem, but haven't been able to as of yet. I'm posting this in case others experience the same issue. If this is common, perhaps someone will come up with a calculation routine for the data that's a bit more realistic. Here's a sample from today:
Code:
RPM		Load2Byte		MAP
1781.25		101.5625		1.74812
1843.75		104.375		1.74812
1875		105.9375		1.74812
1906.25		105.625		2.13498
1937.5		106.5625		2.52184
1968.75		110.3125		2.71527
2031.25		111.875		2.71527
2062.5		115.9375		2.71527
2125		117.8125		3.10213
2156.25		120.3125		3.29556
2187.5		122.1875		3.68242
2250		124.0625		3.87585
2312.5		127.1875		4.06928
2343.75		130		4.26271
2406.25		132.8125		4.843
2437.5		136.5625		5.03643
2500		140.625		5.22986
2562.5		145.625		6.00358
2593.75		149.375		6.39044
2656.25		154.6875		7.16416
2718.75		159.0625		7.74445
2781.25		163.125		8.51817
2843.75		168.4375		9.09846
2906.25		175		10.25904
2968.75		180		11.03276
3062.5		188.75		12.19334
3125		196.875		13.35392
3218.75		204.6875		15.09479
3281.25		214.0625		16.25537
3375		227.5		17.99624
3468.75		239.6875		20.3174
3562.5		255.9375		22.05827
3656.25		274.6875		23.60571
3781.25		292.8125		26.1203
3875		299.0625		28.82832
4031.25		295.3125		29.21518
4125		291.875		29.9889
4250		288.125		28.44146
4375		278.125		28.63489
4500		275.625		27.28088
4625		281.5625		28.24803
4750		285.3125		27.47431
4812.5		287.5		28.44146
5000		282.8125		27.47431
5093.75		282.1875		27.47431
5187.5		281.25		26.31373
5312.5		282.1875		26.1203
5406.25		281.875		26.1203
5531.25		281.5625		25.73344
5593.75		280.625		25.34658
5718.75		278.4375		24.95972
5843.75		274.375		24.57286
5937.5		273.75		25.15315
6031.25		270.9375		24.57286
6125		268.4375		23.60571
6250		265.625		23.79914
6312.5		262.8125		22.63856
6437.5		260		23.21885
6531.25		258.125		21.86484
6625		255.625		22.05827
6718.75		252.5		21.86484
6781.25		250		20.89769
6875		247.1875		21.47798
6968.75		246.25		21.28455
Old Apr 25, 2007 | 12:06 AM
  #212
andenbre's Avatar
unfortunately my life situations haven't allowed me to get my sensor in and logged even though I modded my rom last week and have everything sitting. I will give it a shot tomorrow or thursday and let you know what I get
Old Apr 25, 2007 | 05:32 AM
  #213
TouringBubble's Avatar
It looks to me that the JDM MAP readings are pretty close compared to your load values. Where is your GM MAP located?
Old Apr 25, 2007 | 09:23 AM
  #214
Pd1's Avatar
Pd1
I'm using straight Cali 91 octane and there was no more than 2 counts of knock anywhere in that log. It's been my experience, and many others, that anything on this fuel above about 23psi on a stock-ish turbo will result in a very knock-prone condition. This, combined with the readings from the GM 3BAR (tapped at the standard FPR location) make me question the validity of the JDM MAP readings.
As for the load numbers, the IX + FPGreen and Cosworth cams justify those numbers at a much lower boost pressure than logged by the JDM MAP.
Old Apr 25, 2007 | 01:27 PM
  #215
Max Power's Avatar
Is there any way you could plot the values on the same graph (with rpm on the x-axis)?
Old Apr 25, 2007 | 01:35 PM
  #216
I agree about the load numbers on that turbo. I didn't look at your sig.
An answer to the difference between that sensors would be helpful.
Old Apr 25, 2007 | 01:39 PM
  #217
Pd1's Avatar
Pd1
Unfortunately no. Sorry. I'm not datalogging with the 3BAR since I attached the serial cable to my wideband. I'm also not using ECU+ since I bought the IX (different harness). All I've got at this point is the 3BAR sensor and the Autometer gauge that came with it. I was hoping to sell these soon since I've got the JDM MAP installed now.
Old Apr 25, 2007 | 02:07 PM
  #218
mrfred's Avatar
update
1.joedr: shipped 4/25/07
2.razorlab x2: shipped 4/13/07
3.Andenbre: shipped 4/13/07
4.Ralph: shipped 4/25/07
5.Laakness: shipped 4/13/07
6.Phenem: shipped 4/13/07
7.Max Power: shipped 4/25/07
8.Pd1: shipping 4/13/07
9.fixem2: shipped 4/25/07
Old Apr 25, 2007 | 04:02 PM
  #219
Max Power's Avatar
Ah, no problem. I was trying to see if it was an offset problem or maybe a scaling problem. I'm sure the truly smart programmers will figure it out though
Are the both showing the same vacuum readings at idle?
Old Apr 25, 2007 | 04:49 PM
  #220
Pd1's Avatar
Pd1
Nope. The JDM MAP is reading -6psi, and my GM 3BAR reads about -13 in/hg. It seems to read high all over.
Old Apr 26, 2007 | 06:03 AM
  #221
Max Power's Avatar
Hmmm, I know this is a long shot, but on the coding the equation is given as 1.334*x*14.5/100-14.5
Even though this looks like a conversion from kPa to psi (14.5/100), I'm wondering if there's a problem with the -14.5 term. What is the value of x here?
Old Apr 26, 2007 | 06:41 AM
  #222
burnmacs's Avatar
I don't think I'm missing something here , but -13 inHg = -6.385 psi
http://www.convert-me.com/en/convert/pressure
Old Apr 26, 2007 | 08:10 AM
  #223
mrfred's Avatar
Good find. I had assumed -13 inHg was something closer to -8 to -9 psi. I had Pd1 log the raw MAP data with the engine idling. The average raw value at idle was around 41, so the pressure calculation is 14.5*(1.334*41/100 - 1) = -6.6 psi. So it seems that the JDM sensor matches the GM 3 bar at idle.
Old Apr 26, 2007 | 08:35 AM
  #224
Ralph's Avatar
That is good to hear, I got scared for a second there..... lol.
Old Apr 26, 2007 | 08:48 AM
  #225
mrfred's Avatar
There is still the issue of why its apparently reading high at higher boost levels. It would be great if someone else with a IX could install their sensor to get some data.
