JDM Evo IX MAP sensor group buy
Old Apr 27, 2007 | 10:50 PM
  #241
nj1266's Avatar
Did anyone try connecting their JDM MAP sensor to an electric gauge?
I am on the list for a JDM MAP sensor and would like to know if I can tap into the harness and get a wire to my XD-16/LMA-3 so I can dispaly the JDM boost on the gauge. I know that there are three wires in the MAP harness. A gray harness for 5volt power, a black wire which could be ground, and a yellow wire. Is the yellow wire the signal that goes to the ECU?
Also does anyone have the voltage to boost specs for the JDM MAP sensor?
Old Apr 28, 2007 | 01:00 AM
  #242
Ralph's Avatar
Drove around tonight, got a CEL.. hopefully we can fix this .
I'm using 88590013.xml and followed instructions.. :|
Old Apr 28, 2007 | 10:14 AM
  #243
mrfred's Avatar
Can you pull the code? Schucks/Kragen/Autozone will do it for free.
Old Apr 28, 2007 | 01:10 PM
  #244
mrfred's Avatar
Originally Posted by RedV
You guys are making me SO jealous.
mrfred,
Any word on when the next shipment of sensors might be ready?
Soon. Looks like early May now.
Old Apr 28, 2007 | 02:45 PM
  #245
mrfred's Avatar
Here you go:
https://www.evolutionm.net/forums/sh...13#post3675213
The voltage vs pressure correlations are in the plot.
Old Apr 28, 2007 | 03:35 PM
  #246
RedV's Avatar
YAY! Thanks man!
Old Apr 28, 2007 | 04:54 PM
  #247
burnmacs's Avatar
I know I'm glad I got on the list a few weeks ago!
Old Apr 28, 2007 | 08:46 PM
  #248
phenem's Avatar
mrfred,
I noticed what is going on. Whenever the ECU is checking for emission's it flags the SES light. It logs 2 x P1400 codes. The code says something about EGR emmission control. It only happens every now and then. Sometimes you can drive for a while and other times it happens right away.
~Zach
Old Apr 29, 2007 | 09:37 AM
  #249
mrfred's Avatar
Originally Posted by phenem
mrfred,
~Zach
Yeah, that's the code that is supposed to indicate that the EGR system is not working. The job of the MAP sensor on USDM cars is to detect a change in manifold vacuum when the EGR valve opens. The JDM sensor has a lower sensitivity to changes in pressure, so using it with the USDM MAP translation tables causes the ECU to think that the pressure change is too small. Once the table locations are found, this can be fixed.
Old Apr 29, 2007 | 12:01 PM
  #250
phenem's Avatar
Can we just eliminate EGR system completely? Will this cause people in states that need the OBD-II tests to fail? If possible just bypass it completely and block off the EGR port on the Intake Manifold.
Would this be easier, rather than find the tables and still run EGR emissions?
~Zach
Old Apr 29, 2007 | 06:06 PM
  #251
mrfred's Avatar
It may take a while to find the tables, but for the end user, modifying the tables would be much easier than physically eliminating the EGR system. Now that I think about it, there is a way within the ECU to shut off the EGR system. This would mess up emissions testing though, and I don't know how the car would run the the EGR disabled. The exhaust gas is meant to help control EGTs when running very lean at cruise.
Old May 3, 2007 | 07:05 AM
  #252
fixem2's Avatar
Any updates on the CEL fix?
Old May 3, 2007 | 07:18 AM
  #253
mrfred's Avatar
Nothing yet. I had to take a break from looking at the Evo 8 code to deal with other things. I'll start looking at it again after this weekend.
Old May 7, 2007 | 11:11 PM
  #254
Max Power's Avatar
Any more luck on the 96940011?
Old May 9, 2007 | 06:33 AM
  #255
fixem2's Avatar
Installed my JDM sensor today and the car would not stay started. It would start but immediatly stall. Put the old sensor in and all was good. ANy thoughts? Car is an EVO 8 with 96940011 Rom.
