ecuflash question obdII
Old Nov 30, 2006 | 04:41 PM
gerard_fs's Avatar
Hi to all!
I have some questions to you;
1-
Can I get self dynoflashed whit standar OBDII elm 327 conector?
like this
or I will need to purchase this other connector??
2-
I have fitted the ralliart ecu on my evo VIII,
can I read the ralliart ecu, and flash the OEM ecu with ralliart maps with ecuflash??
thanksss
Old Nov 30, 2006 | 09:07 PM
MalibuJack's Avatar
You need the Openport cable (the bottom picture) you will not be able to reflash with any elm based OBD-II scanner.. and the bottom cable has a special second connector (the white one) which allows the ECU to accept the reflashing.
Old Dec 1, 2006 | 01:02 AM
gerard_fs's Avatar
ok, thanks,
where can I purchase the bottom picture OBDII cable??
Old Dec 1, 2006 | 06:11 AM
donour's Avatar
Originally Posted by gerard_fs
ok, thanks,
www.tactrix.com
To add to Jack's point, you can't really reflash with ANY normal OBDII cable (elm or not) because you still need the extra wire to put the ECU into boot mode.
d
Old Dec 1, 2006 | 09:17 AM
gerard_fs's Avatar
ok,
thanks to all, mitsu open port tactrix bought
whit the open port, and the ecuflash program, could I read the ralliart ecu, and flash my OEM ecu whit the ralliart maps??
sorry if is a stupid question
Old Dec 1, 2006 | 11:20 AM
donour's Avatar
ok,
Are you talking about the the Evo ECU that is sold by ralliart or an ECU from a lancer ralliart?
The latter, no. The former, I'm not sure. I don't know if the ralliart branded Evo ECU is just a remapped stock ECU or if actually a different unit.
d
Old Dec 1, 2006 | 01:42 PM
gerard_fs's Avatar
Its a remapped stock ecu by ralliart, the branded ralliart ecu is WHite, and mines is black, identic with my stock Ecu, just change the sticker and the ref. nº.
many thanks
Old Dec 1, 2006 | 01:48 PM
hopper's Avatar
Hmm this makes me ponder on how Cobbs accessport is going to work.... They said that maps can be selected through the obd port....
Koroshiya
21
Nov 18, 2025 12:17 AM
evoscan
52
Jun 20, 2017 01:46 AM
KOTT
Sep 17, 2008 08:59 AM
mikron15
Lancer Engine Management / Tuning Forums
Jul 19, 2008 11:59 PM
jid2
Apr 8, 2008 01:57 PM
