ECUFlash / Evoscan / Mitsulogger Questions
Old Mar 19, 2010 | 01:15 PM
  #721
BillSpec's Avatar
The highest RPM i can seem to log with V7 Evo IX, and 2.6 is 8000.
I rev to 8500 on a HTA 35r... am I missing a table adjustment in evoscan or something?
Old Mar 20, 2010 | 11:47 AM
  #722
BillSpec's Avatar
Old Mar 21, 2010 | 02:54 AM
  #723
monkeyevo's Avatar
Got evoscan 2.6 now I would like to learn about tuning.Can anyone tell me how to use the evoscan, and how to log data. I wanna see my HP please explain details and what Do i need to adjust before start logging because I'm baby with this program So.. you guys can PM me about this too. any recommend or suggestion would be appreciated !
Thanks in advance
Old Mar 21, 2010 | 08:03 AM
  #724
evo_gerard's Avatar
hey how do i use the 1 byte load logging? i'm using 90550001 tephra 5.10 and i'm logging with mitsulogger cuz i have an aem wideband. do i need to make any xml changes in either ecuflash or mitsulogger? also what do i need to select in mitsulogger to log 1 byte load?
please help me with this
gerard
Old Mar 23, 2010 | 12:57 PM
  #725
mitsuEVO8kid's Avatar
Thanks in advance
Look at the "How to Tune an Evo". You will need a tactrix cable to connect to your evo. There is a video on youtube which helps you start up. Just type in "EvoScan" and there should be a little tutorial on how to start
Old Mar 24, 2010 | 09:09 PM
  #726
Rome-Evo's Avatar
Question... i have evoscan v2.6 with an 03 evo and i just got the tactrix cable.. i want to know how to log my power and speed with evo scan.. if you can help. also are there any user guides floating out there on how to operate evoscan.?? thanks ...
Old Mar 25, 2010 | 01:54 AM
  #727
monkeyevo's Avatar
I got everything But how to log to see HP and Tq ? Just select start logging and start log from 2500RPM to 7000RPM and stop logging ? or what i need to do for the log ? and after log how I can get the graph for HP and Tq. If anyone would help describe step by step that would be cool!
thanks
Old Mar 25, 2010 | 04:45 AM
  #728
metalsaber's Avatar
Download the Virtual Dyno Room (VDR) Excel file.
https://www.evolutionm.net/forums/ec...simulator.html
Everything you need to know is in that thread. Just copy in the RPM and LogEntrySecond columns into the excel file. Update the spreadsheet with your cars specific info and you are good to go.
Old Mar 25, 2010 | 06:33 PM
  #729
markyang83's Avatar
hi guys
any one know if EvoScan GPS Navigator will work with tactrix open port 2.0? And how please!!!
thanks
mark
Old Mar 27, 2010 | 06:07 AM
  #730
bizaarhatch's Avatar
Kk. Can't help ne one else, but my load tables just go to 100%! ECU flash goes to 300, but on evo scan I can just get it to read 100. How can I fix that?
Old Mar 31, 2010 | 09:56 AM
  #731
geevolution's Avatar
Got the Limitless Designs 1.3U cable, confused as to which software to use to disable the P0300 test, and force OBD inspection to pass. Ecuflash, or would I have to purchase evoscan? Inspection is way overdue, need help asap. Thanks Guys!
Old Mar 31, 2010 | 10:00 AM
  #732
metalsaber's Avatar
You would need ECUFlash to disable the code.
Old Apr 6, 2010 | 04:36 PM
  #733
Thanks, by any chance would you know where the license number would be located? It's supposed to be included with the cable that I bought.
Old Apr 6, 2010 | 06:22 PM
  #734
ilikeppie's Avatar
So i finally hooked up the cable so i could log the AEM UEGO it works for about 30 seconds then the AFR reading freezes i am running windows 7 and logging with evoscan 2.6 and i have a tactrix cable 2.0
Old Apr 6, 2010 | 07:33 PM
  #735
metalsaber's Avatar
You don't need an license # to use ECUFLash. What cable do you have? If you bought a 1.3 series cable, you need the 1.3U cable to reflash your ROM.
