ECUFlash / Evoscan / Mitsulogger Questions
Old Oct 13, 2011 | 04:31 AM
  #1096
orkhan335's Avatar
Originally Posted by PrimerSdime
Expand the idle tab in EcuFlash, then open up the "desired idle rpm - neutral", table.
I have them when i want to add map, but they aregrey and i can't edit them...
Error:
"the current map description is invalid or incomplete. please edit map description to fix the problem and the map will be viewable again"
Old Oct 22, 2011 | 12:07 PM
  #1097
bnr34rb26dett's Avatar
hmm im getting thsi error when i try to read the ECU on USDM evo 8 does anybody know what im missing? sorry im a super noob
Old Oct 27, 2011 | 04:31 AM
  #1098
babaz7's Avatar
hi, how do i increase the load cells in ecuflash? i think im hitting higer load cells than 260...please tell me the whole procedure step by step..
Old Oct 27, 2011 | 09:08 AM
  #1099
PrimerSdime's Avatar
https://www.evolutionm.net/forums/ec...-viii-ecu.html
Old Nov 5, 2011 | 10:56 PM
  #1100
AndyCT9W's Avatar
Quick question. I have an evo 9 GT wagon (has it's own unique ROM) and the stationery rev limit is set at 7969. It seems as though it's been set to be disabled from the factory. To activate it, do I need to do anything else other than lower the figure?
Also, there are a few tephra tables in my XML that haven't been set (e.g. knocksum for CEL is 65535). If I flash without putting figures into these tables could it do any harm?
Cheers.
Old Nov 6, 2011 | 12:03 AM
  #1101
tscompusa's Avatar
Cheers.
lower it and it will become active..
no the 65535 is just because the address is pointing to the wrong sub routine code. the address is linked in the xml file. it has no impact on the actual rom image unless you alter that number then write new data to the rom.
Old Nov 6, 2011 | 12:36 AM
  #1102
AndyCT9W's Avatar
Thanks, I remember reading something about launch maps. I can't remember where. My friend has been going on about how great his is in his 9 gsr even though I told him how to use it. Will try it out very soon.
Old Nov 6, 2011 | 01:05 AM
  #1103
chaosfiend21's Avatar
is mitulogger still available?
Old Nov 6, 2011 | 08:51 PM
  #1104
AndyCT9W's Avatar
Just flashed with a 4k (for now) stationery limit. Works mint, cheers heaps.
So the tephra is wrong for my ROM? The knocksum for CEL has the wrong address and shouldn't be touched?
Old Nov 6, 2011 | 08:54 PM
  #1105
Good, now raise it to about 6,000 and put it to work.
Old Nov 6, 2011 | 08:58 PM
  #1106
AndyCT9W's Avatar
I downloaded mitsulogger a few months ago, I can't remember where I got it from. I found this link in another thread http://evoecu.logic.net/mirror/svn/tools/MitsuLogger/
I don't know if it works, but evoecu is really reliable source for a lot of tuning resources.
Edit: I have the zip file on my computer, I can post it if it's ok with the rules.
Old Nov 6, 2011 | 09:06 PM
  #1107
AndyCT9W's Avatar
I've had it 6 months (despite spending most my life around performance cars I've only recently got one), I'm still going over the car. I keep finding stuff in it and about it. I've got no use for the gizzmo launch interface now. Clutch is dragging, pedal has been adjusted correctly, huge improvement but still dragging a bit.
That said: Night speed drag wars (our annual drag competition for street cars) is up and going..............mighty tempting.
Old Nov 6, 2011 | 09:08 PM
  #1108
tscompusa's Avatar
yes either that or your xml has false info in it. do not touch it if the values read like that.
set your 2 step to around 5500 and youll get perfect launches. you'll notice 5500 rpm will be actually around 5700 also when you test it.
when you launch slip the clutch slow.. never leave it up fast or u will blow your drivetrain out.
Old Nov 6, 2011 | 09:16 PM
  #1109
AndyCT9W's Avatar
Thanks heaps. I'm going to move into this at a moderate pace so I will work my way towards 5500, I have very few launches under my belt and I can't afford to break anything.
I noticed when I set it to 4k, the RPM actually sat just above. That's because of the multiple translations of code between ecuflash and the ecu? or the ecu has trouble controlling the RPM exactly when doing stationery rev limit?
Edit: I got 6-7 psi of boost at 4k, does that increase with RPM or is that what is expected?
Old Nov 6, 2011 | 09:51 PM
  #1110
Lol, that might be good for the street. I leave at 6,000 when im at the track...anything lower and the car does'nt leave as hard.
I make about 10 psi at 6,000 without using launch maps.
