ECUFlash / Evoscan / Mitsulogger Questions
Old Nov 13, 2011 | 09:54 PM
  #1111
izabran's Avatar
Originally Posted by bnr34rb26dett
hmm im getting thsi error when i try to read the ECU on USDM evo 8 does anybody know what im missing? sorry im a super noob
i'm getting the same thing anyone... my ecu is locked and i can't seem to get any parameters...
Old Nov 13, 2011 | 11:32 PM
  #1112
AndyCT9W's Avatar
It appears (I'm no pro) as if you are missing the XML definition file. Do you know your ROM ID? If you don't, specifically what model is your evo?
Old Nov 13, 2011 | 11:53 PM
  #1113
And's Avatar
And
at that point if you click next it should tell you the rom id, you should then download it and then reopen it and you should be good
Old Nov 16, 2011 | 08:56 PM
  #1114
chaosfiend21's Avatar
evoscan reads about 400 rpms lower than actual any input?
Old Nov 21, 2011 | 04:51 AM
  #1115
5speedwtneed's Avatar
okay im stumped and cant find the solution, well im sure i could if i scanned through a 100 pages of this thread lol. when using my tactrix cable, i can log in evo scan no problem. but when it comes to ecu flash it acts like it is impossible to make a connection. Im really doing this just to do the rear 02 sensor CEL pass but i cant get it to read the ROM. all it says is unable to connect to vehicle interface. no errors no unknown errors or locked issues. just cant connect... any help? im sure this is easy, hoping for a helpful reply. thanks
Old Nov 21, 2011 | 09:47 AM
  #1116
AndyCT9W's Avatar
Try using ecu unlocker. Just download it and open it and have it running in the background when your try to read your rom. Also when you start to read your rom, have the car running. The car will turn off when you start to read, but this ensures your battery has the max voltage when you try to read.
If that doesn't work, can you copy and paste your log into a post.
Old Nov 21, 2011 | 10:01 AM
  #1117
Might have figured my problem out
Old Nov 21, 2011 | 12:28 PM
  #1118
Old Nov 21, 2011 | 05:25 PM
  #1119
Okay I'm still screwed. Cannot retrieve the ROM....
Cable plugged into car and laptop.
Turn car to on but not started.
Start ecu unlocker
Start ecu flash
Retrieve rom
Cannot interact with ecu. What the heck...
Voltage is good. I cannot figure this out. Any ideas. I even tried with car running. No luck.
Old Nov 21, 2011 | 06:29 PM
  #1120
AndyCT9W's Avatar
Which cable are you using? One with two ports into the vehicle?
Old Nov 21, 2011 | 07:08 PM
  #1121
Yeah two ports... The second one only has one wire... Please tell me it's the right one
Old Nov 21, 2011 | 08:39 PM
  #1122
Jeff_Jeske's Avatar
I recently upgraded my turbo and am now taking a closer look at what evoscan captures while logging. One area that doesn't pass the smell test is the Baro reading. Almost all of my logged baro readings are 96.04 with the occasional drop into the 91 range.
My EVOScan 2.8 baro formula is 0.49*x. Should I be using a different formual and if so what is it? Thanks in advance!
Old Nov 21, 2011 | 11:26 PM
  #1123
AndyCT9W's Avatar
Yeah, sounds like the right one. Do you know the name of the cable you're using? Can you post the log from the read attempt?
Old Nov 22, 2011 | 03:38 PM
  #1124
Log says.
"using interface OpenPort 1.3 Universal"
"(bunch of gibberish code)"
"interface close"
"unable to connect to vehicle interface"
Old Nov 22, 2011 | 04:02 PM
  #1125
1 EvoScan 1.3R USB Datalogging and Reflashing Cable
(Additional Software with Any Purchase: Evoscan Windows Software (Win2k/WinXP/Vista/Win7/64bit) (+ $20.00)
Optional StandAlone Touchscreen device: None
Evo AYC/ACD or Subaru Reflash Support Required?: Evo7/8/9 AYC/ACD Support
That's my purchase order with Evoscan included
