ECUFlash / Evoscan / Mitsulogger Questions
Old Oct 8, 2011 | 09:18 AM
  #1081
03Ev0luti0n's Avatar
I had nothing but problems with the innovate LC-1 constantly having to recalibrate. i tried both methods LED and Evoscan... I shipped the unit back to innovate twice... issue still not resolved... i trashed the innovate and i switched to the AEM UEGO.. best decision i made. no recalibration complete plug and play.. and no issues trying to log... AEM is well worth not having to deal with the recalibration and headache that comes with it..
i know this doesnt help your problem but maybe it will help others who are in the market for a WB02. Every one posted how great the innovate was considering the price... the AEM was easier to install no giant LC-1 to try and hide. AEM's directions are simple to follow. Yeah you may save an extra 15-20$ but its not worth the hassle with innovate IMO..
Old Oct 8, 2011 | 09:39 AM
  #1082
EvoIIIAj's Avatar
EvoScan
Hi guys,
I have a few questions..
I have a JDM Evo VIII. I think my ECU is different from USDM Evo VIII's correct? I think I have 3 connections in the back and you guys have 4, or it's the other way around.
Anyways, I will be tuning soon and I want to have my AEM wideband wired into the ECU to log AFRs in EvoScan, I see a tutorial on how to do this, but the ECU pin out is for a USDM Evo VIII would be different than mine I assume. If anyone has any info that would help me I'd appreciate it...
Old Oct 8, 2011 | 06:54 PM
  #1083
PrimerSdime's Avatar
I'm starting to think that all of the problems people have with the LC-1's are user error. I was somewhat worried about the LC-1's prior to installing mine. But, I hooked mine up and it worked flawlessly.
Old Oct 9, 2011 | 08:45 PM
  #1084
babaz7's Avatar
okay i have 2 questions,plz try to answer
1.im tuning my fuel trims,so when i want to change the scaling of my injectors should i just change the scaling in evoscan or have to change it in ecuflash and the reflash the car for the scalings to be what i want?
2.i cannot change the scaling value in ecuflash its stuck at 1271 it doesnt increment or decrement,whats wrong?
Old Oct 10, 2011 | 10:47 AM
  #1085
1. The value in EvoScan is for datalogging purposes. Used to calculate duty cycle, etc.. You need to modify the value in EcuFlash to make changes.
2. To change the value in EcuFlash you must click on the value, hit enter on your keyboard, type in the new value and hit enter again.
Old Oct 10, 2011 | 10:54 AM
  #1086
Originally Posted by EvoIIIAj
Hi guys,
http://www.lancerregister.com/showthread.php?t=196839
Try that, I think it may be what you are looking for.
Old Oct 10, 2011 | 11:43 AM
  #1087
a lot of them probably are.. i kept getting flashing LED error codes because the LC-1 was bad...
if it was "user error" just proves my point that the AEM is more "user friendly"
Old Oct 11, 2011 | 12:14 AM
  #1088
babaz7's Avatar
thanks man it worked but now i have another problem, the value will not be what i want,for example right now its at 1271 but i want it to be 1290 when i enter 1290 nothing happens but if i enter 1300 it goes to 1329 what value do i have to add to bring it to 1290?
Old Oct 11, 2011 | 10:44 AM
  #1089
Sometimes the value won't go to what you want it to be exactly, it's just how EcuFlash displays the information. Just make it as close as possible to what you want.
Old Oct 11, 2011 | 10:46 AM
  #1090
I agree with you there. From what I hear about the AEM's, they are much easier to install.
Old Oct 13, 2011 | 03:10 AM
  #1091
orkhan335's Avatar
Hello all
Tell me plz how I can change minimum RPM from 750 to 850 in ECU FLASH?
Old Oct 13, 2011 | 03:45 AM
  #1092
Originally Posted by orkhan335
Hello all
Minimum RPM? Do you mean your idle speed?
Old Oct 13, 2011 | 03:59 AM
  #1093
orkhan335's Avatar
I think yes when i'm not driving and staying in one place my RPM show 750 i need increase it to 850.
Old Oct 13, 2011 | 04:14 AM
  #1094
Expand the idle tab in EcuFlash, then open up the "desired idle rpm - neutral", table.
Old Oct 13, 2011 | 04:19 AM
  #1095
orkhan335's Avatar
I haven't IDLE tab no expand function... I think i must add it from xml?
