ECUFlash / Evoscan / Mitsulogger Questions
Old May 2, 2013 | 08:01 AM
  #1426
shkettle's Avatar
I Believe that i need to add tephra v7 to my ecu flash. i am currently researching this...
Old May 2, 2013 | 08:20 AM
  #1427
evo8426's Avatar
Yes you need to add the XML files from the V7 thread. I was able to open it up no problem with the correct files.
Old May 2, 2013 | 03:52 PM
  #1428
shkettle's Avatar
thats what i thought. im still tring to figure it out how to add it. lol
Old May 14, 2013 | 10:53 PM
  #1429
mines5's Avatar
Hi, i am new to ecu flash , can any body clear this thing out
a value of 5 in the hi octane ignition table represents spark is being fired 5 degree BTDC ?
a value of 0 in the same table represents ?
a value of -10 in the same table represents ?
or +ve is just taken as advance and -ve is just taken as retarded timing ?
Old May 22, 2013 | 10:59 AM
  #1430
FLASH1970's Avatar
First off let me apologize for the crappy cell phone pic of my computer screen. I did the log on my way to work and they're wifi ***** here so I took this pic of my laptop at lunch and I'm on my phone posting this. I thought WWMD... What Would MacGyver Do. Anyway, my afr map calls for 14.7 and my wideband shows roughly 15.2 when I play back the datalog. How can I rescaled the vertical axis of the graph so my afr numbers match the number on the graph axis?
Attached Thumbnails ECUFlash / Evoscan / Mitsulogger Questions-2013-05-22-12.47.11.jpg
Old May 30, 2013 | 12:33 PM
  #1431
ApacheToYaDome's Avatar
I need help, I had EvoScan and ECUflash on my old laptop (windows 7) it crashed and I bought a new laptop currently running windows 8. I was able to download EvoScan but when I try and download ECUflash it downloads, and I click on the installer, it goes through its thing to get the drivers and everything working. But when it's done I click on ECUflash and nothing happens. It downloads correctly and all of the files seem to be there. I just can't launch it. Could this possibly be a windows 8 thing? If someone has experienced this please point me in the right direction. I've tried deleting it and reinstalling but still the same thing happens.
Old May 30, 2013 | 04:10 PM
  #1432
curamrdan's Avatar
Is it normal, that on my 2004 EU VIII i cannot read ACD faults and also im not able to bleed air? I bought cable mainly for this
Lastest evoscan 2.9.0023 . Have 3lights problem(probably know where is the fault, but...).
Limitless 1.3U cable with removed pin9. Tried MTUIII and OBD2 option.
Old Jun 6, 2013 | 06:49 PM
  #1433
MrSquirr3l's Avatar
so i have been having issue with getting my launch maps to activate. My set up is not you typical set up due to the car. so i have a 2003 eclipse gs-t and i am running v7 on the eclipses ecu. rom is 96530706.
now my suspicion is that the launch maps activate with a combo of flooring the throttle and holding the clutch at the same time. i have not been able to verify the exact pins for the clutch from a evo harness/ecu to the eclipses. However could there be any other reason for this feature to not work? before anyone asks yes i do have it enabled in the options.
Old Jun 6, 2013 | 10:10 PM
  #1434
And's Avatar
And
I believe the launch works off just the rpm and the speed from the gearbox. The nlts.uses the clutch switch
Is the ecu seeing the speed correct?
Old Jun 6, 2013 | 10:15 PM
  #1435
MrSquirr3l's Avatar
you are correct and i am not so smart. so i tried it again and it will not hold it at the stationary rev limit. i set it to 5k to test and it feels like it starts to hold it then it bounces maybe two-three times and then jumps up to the cars rev limit.
Old Jun 10, 2013 | 08:09 PM
  #1436
mines5's Avatar
I have added 2 byte load to my rom's xml file but i dont see any option in Mitsulogger Log reference for 2byte load, RPM.
What codes should i need to add to mitsulogger xml for 2 byte load and rpm?
ROM id is JDM 2004 93660005
Thanks.
Old Jul 19, 2013 | 05:49 PM
  #1437
gotpsi?'s Avatar
Ok I dont know if this has been asked before but, I have evoscan 2.9 and log load using 1byte and it seems when I exceed 300is load it starts over for example if I run a log and bring the car up I will see in my log a steady rise as boost increases but once it hits 300 load the next number will be 8 or 30 and then climb from there to around 100 depending on the boost I'm running. how can I get this to work right? I know that when I see 30 at that point in time its really 330. how can I correct this.
Old Jul 20, 2013 | 12:13 AM
  #1438
And's Avatar
And
You need to change the 1byte multiplier both in evoscan and ecuflash to 1.3 instead of 1.2
Andy
Old Jul 21, 2013 | 11:56 AM
  #1439
gotpsi?'s Avatar
ok, I know how to do that in evo scan but how about in ecu flash?
Old Aug 6, 2013 | 10:30 AM
  #1440
Tas evo7,04/636's Avatar
If I get 1.3r or 1.3U cable and ecoflash can I just edit speed limitor cut on my Aust JDM evo 7gta? aswell as raise boost cut slightly,paise octane level and with not to many difficulties or do I have to do a total reflash once edited those things or it just possible to edit...I am fairly new to this side of things so an input or help would be greatly appreciated
