Engine stumbles... can this be tuned out?
Old Dec 20, 2006 | 11:01 AM
Evo442's Avatar
When I am accelerating hard and abruptly lift the throttle - like when someone cuts you off... my evo bucks/stumbles a fair bit.
Some of can be alleviated by lifting less abruptly, but can some of this be dialed out with ecuflash?
Old Dec 20, 2006 | 11:25 AM
dubbleugly01's Avatar
what type of bov are you running? What type of air intake are you running?
These are usually the culprits. Aftermarket tube style intakes with a cone filter and VTA bov's are the major cause of the typical stumbles. There are a couple people working diligently to help cure these issues using ecuflash, but their not quite there yet.
Old Dec 20, 2006 | 11:27 AM
Evo442's Avatar
Works diverter valve, works air filter.
Old Dec 20, 2006 | 11:28 AM
EvoAnthony's Avatar
Loosen the BOV a little if you have an aftermarket one....it is stumbling because of the trapped air in the pipes when you let off.
Old Dec 20, 2006 | 11:29 AM
rcheung's Avatar
I think I know what you mean It happened to me after I got my flash because I got more power. When I drive it fairly hard then suddenly let go of the gas, it kicks for like a second because its no longer pulling so hard. It has nothing to do with the tune if thats what you mean.
Old Dec 20, 2006 | 11:54 AM
jcsbanks's Avatar
Evos do this standard IMHO. Lots of intercooler piping and a MAF sensor.
Old Dec 20, 2006 | 12:03 PM
RazorLab's Avatar
So Mitsu MR BOV and K&N Filter?
Have you got your 720cc injectors all dialed in via fuel trims etc? How bad is the stumble?
This is usually caused be a overly abrupt change in fueling between WOT --> mid --> low load. Like what you would do while feathering the throttle in a turn or letting off quickly. Check your fuel cells in those transitional areas in the fuel maps.
A load bearing steady state dyno would work well here.
Old Dec 20, 2006 | 05:53 PM
Evo442's Avatar
No, dont have the 720's dialed in yet. Was a minor annoyance prior to the new injectors, but now its a little worse. Just got the wideband installed today, unfortunately, my egt probe is loose and needs to be fixed. Need to do some datalogs... and check fuel maps. thx!
Old Dec 20, 2006 | 06:25 PM
RazorLab's Avatar
If you had it before the injectors, check for air leaks.
Old Dec 20, 2006 | 06:34 PM
Mivecless's Avatar
Your BOV is likely installed BACKWARDS.
Old Jan 2, 2007 | 10:28 PM
559EVO's Avatar
Put the stock bov back on.
Old Jan 3, 2007 | 11:01 PM
evo4mad's Avatar
I disagree about the BOV thing. I have two ECUs wired up to my car on a switch, one is a stock ROM and the other is a ralliart ROM, and boy does it jutter badly between WOT and low load when using the ralliart ECU, and is perfectly smooth with the stock ECU.
I think Evo442 and razorlab are right, it is ALL in the tune... and I also think it is heavily to do with the fuel trims and fuel maps.
Anybody with ideas on what to tune with or without a dyno?
alexc
Feb 23, 2015 08:06 PM
vr4gasmtt
Oct 29, 2014 02:23 PM
EvoPower81
Sep 9, 2010 01:10 PM
Noize
Mar 24, 2008 03:27 PM
2.3 Evo 8
May 12, 2007 09:02 AM
