mitsulogger???
Old Feb 18, 2007 | 04:27 PM
evoboy8990's Avatar
mitsulogger???
how do i use Mitsulogger 1.5v? im new to the software, never heard of it. i already installed the software, im not sure how to use it and what is does? can u please help me out with what to do.
Old Feb 18, 2007 | 09:16 PM
evo_whiplash's Avatar
I am also looking for a simple set of instructions for using mitsulogger. Have looked around at the capabilities but I have not attempted to use it because I do not have a clear understanding of how to use to software.
Old Feb 18, 2007 | 09:27 PM
mercedevo's Avatar
It logs your cars data when running so you can review the data for tunning.
You will need a cable to connect to your cars OBDII port in order to use the program.
Old Feb 18, 2007 | 09:29 PM
eponti's Avatar
make sure that you have a tactrix cable.The logger tells you if your engine knocks at high RPM.
Old Feb 19, 2007 | 08:27 AM
evoboy8990's Avatar
i have a tactrix cable but im not sure what to do after that, i know u connect the cable to ur ecu, but to get the data u gota do a pull or nething? do i have to drive the car to get the data?
Old Feb 19, 2007 | 08:35 AM
MalibuJack's Avatar
Yes, you have to drive the car to get the data.. Logging will capture whatever data from whatever your doing at that time. If you need a third gear pull, you need to log data while your doing the pull.
mines5
Jun 18, 2013 09:49 AM
chaz517
Sep 29, 2007 07:22 AM
evolrobert
May 15, 2007 08:08 PM
GTisRule
Northwest Region
Feb 8, 2007 04:13 PM
brobards
Nov 30, 2006 01:18 PM
