libmut help
Old May 24, 2014 | 07:39 AM
  #31
harshadura's Avatar
Hi Guys,
Can anybody point me to the source codes of Evoscan and MUT logger (early versions) may be ?
ty
-harsha
Old May 26, 2014 | 11:15 AM
  #32
donour's Avatar
AFAIK, the evoscan sources aren't generally available. The libmut sources are still at their original location and will be indefinitely: http://www.cs.unm.edu/~donour/cars/libmut/.
That being said, I haven't owned a mitsubishi in a few years so it is likely to get no more updates.
donour
Old May 27, 2014 | 04:11 AM
  #33
harshadura's Avatar
donour
hi donour,
I tried your code, thanks for that. But when I ran the test it didn worked.
I was properly installed FTDI drivers to my linux pc - ubuntu
and also built the libmut lib, config, make, make installed.
then I connected the openport cable to my car and started the engine.
and ran > ./mut_test ~/test.log
it didn worked. it always says "We shouldn't be here - init failed."
but FTDI read commands works properly at FTDI linux driver examples / eeprom /read <ret>
To Remove the VCP driver as described in section 1.1:
sudo rmmod ftdi_sio <ret>
sudo rmmod usbserial <ret>
Run the sample application: sudo ./read <ret>
Could you please help me with it. thanks
Btw this code worked. its referring another set of FTDI commands : https://github.com/niallm90/libftdim...2b12e366d69b5d
Old May 27, 2014 | 05:32 AM
  #34
donour's Avatar
Originally Posted by harshadura
hi donour,
Wow, this one makes me dig deep into my memory. I believe that error is the result of a baudrate error. Do you have any experience programming in C? It's likely an very easy fix.
d
EvoXCa
Evo X How Tos / Installations
Jun 28, 2016 07:11 PM
hispanicpanic
Jul 10, 2015 08:02 AM
michael knight
14
Apr 30, 2013 09:01 PM
mitsuevo803
Aug 19, 2011 09:06 PM
