Leaving the Openport cable plugged in - does it draw power?
Will it flatten the battery? I'm using it so often I don't want to damage the plug/socket...
I know the LEDs stay on on some Elm OBD 2 stuff with ignition off.
Great question... I have a small electrical discharge that completely depletes the battery if I don't drive it for a week or more.
I also leave the cable in all the time, and suspected that it was the problem.
Sorry that I did not answer your question, but knowing that your not is the same boat sometimes helps.
The +12V drive the LM555CM IC permanently. The datasheet of the 555 says that with no load the maximum current is 15mA.
Mine is always plugged in since I am almost always logging data from the ECU. My battery has suffered no ill effects.
Yes, it draws a VERY small amount of power, however the evo has a power management module that shuts power off to the port after 15-20 minutes.
The current drawn by an aftermarket radio's clock circuit draws way more current, not to mention it maintains a constant power where most everything else gets shut down.
If you left your headlight, interior lights on for any period of time it shuts down on its own after 15-20 minutes of the power being off and the doors locked.
LIL EVOL
Apr 3, 2007 10:32 AM
The Emperor
14
Jul 18, 2004 01:22 PM
