Evo IX 2-byte Load & Lean Spool for Dummies
Old Oct 31, 2007, 09:52 PM
  #151
Inprogress's Avatar
Anyone have an answer for what i've posted above?
Old Oct 31, 2007, 09:57 PM
  #152
tephra's Avatar
lean spool instructs the ECU to lean out the AFR's for a given rev range - most people disable it as it makes tuning a little easier/more predictable
Old Oct 31, 2007, 09:58 PM
  #153
Inprogress's Avatar
Thanks for the info tephra, now if only someone could answer this dumb question
Originally Posted by Inprogress
So I just copy and paste these values anywhere in the ROM ID via XML editor?
I'd copy those 2 items right under the red line I've drawn in this image right?
Thanks!
Old Oct 31, 2007, 10:01 PM
  #154
JohnBradley's Avatar
If thats the last line in the ROM at that point, then yes.
Old Oct 31, 2007, 10:14 PM
  #155
Inprogress's Avatar
Yeah, there isn't anything else. Thanks!!
Old Oct 31, 2007, 10:28 PM
  #156
tephra's Avatar
with regards to EcuFlash, just keep backup copies of you ROM and then experiment...
until you "FLASH" back to your car you havn't done any damage... so it can't hurt to try things
Old Oct 31, 2007, 10:49 PM
  #157
Inprogress's Avatar
I'm getting this error, why am I getting this?
Old Oct 31, 2007, 10:58 PM
  #158
tephra's Avatar
Because vista is security conscious you need to save it to somewhere else and the copy it back..
you may even need to save it as a .txt and then copy it back and then rename it back to .xml...
Old Oct 31, 2007, 11:00 PM
  #159
Inprogress's Avatar
So then I just edit it through wordpad when I change it to txt? Then rename it basically right?
Old Oct 31, 2007, 11:05 PM
  #160
tephra's Avatar
yup and stick it (overwrite) the old file in the ecuflash directory...
Old Oct 31, 2007, 11:13 PM
  #161
Inprogress's Avatar
Still won't let me, it says I dont have permission to write in the folder...
i took out the old rom, copied the new one in as a txt doc, then tried to save the old one as a xml doc and didn't work, it gave me the above mentioned error
Old Oct 31, 2007, 11:15 PM
  #162
tephra's Avatar
you got admin rights on you box?
try deleting the file first?
closed EcuFlash just incase?
Old Oct 31, 2007, 11:21 PM
  #163
Inprogress's Avatar
I didn't delete the original 88590015 file, i just cut it and paste it into the documents folder; i do have admin rights, i mean its my personal laptop; so you're suggesting to delete the original 88590015 alltogether?
Sorry for making this more difficult then it should be, just a little slow with this "detailed/expert" adjusting on the comp
Old Oct 31, 2007, 11:27 PM
  #164
Inprogress's Avatar
hallelujah!! Finally got it, thanks for helping me tephra, I REALLY APPRECIATE IT!!!!
Now all I do in evoSCAN is click LOAD MUT 2Byte Mod and RPM MUT 2Byte Mod in the "Items to Data Log" column and I'm set right?
Old Oct 31, 2007, 11:50 PM
  #165
tephra's Avatar
and possibly change the formulas for evoscan... depending on what variable you happened to pick
Quick Reply: Evo IX 2-byte Load & Lean Spool for Dummies
