My First Logs with New Evoscan and LC-1
Old Apr 8, 2007 | 12:42 PM
Stealth Ag's Avatar
The logs are trimmed down to WOT in 3rd gear.....look alright, I am thinking alittle lean, but no knock is present.
I try to use mitsulogger but it crashed whenever i selected my Wideband, possibly because i am using a USB to serial converter, i still have to work that issue out....
File Type: zip
Old Apr 8, 2007 | 12:45 PM
4WS Tuning's Avatar
AFR is all over the place, try to smooth it out. I like tuning to a 11.1 for a conservative tune. You can go lean it out to 11.4-5 if you want.
Cheers!
Old Apr 8, 2007 | 12:48 PM
Stealth Ag's Avatar
it might be a grounding issue for my LC-1 im still looking at that...
Old Apr 18, 2007 | 10:01 AM
Kronik's Avatar
Did you do anything for a setup purpose to get your LC-1 to give AFR readings? When I hook up the LC-1 to logworks it reads correctly. However, when I put this with Evoscan I'm only seeing readings that are 4.XX. Makes no sense??
Old Apr 18, 2007 | 12:17 PM
TouringBubble's Avatar
My LC-1 worked perfectly with EvoScan right out of the box.
Old Apr 18, 2007 | 01:52 PM
Kronik's Avatar
I think I figured out what happened -- I'm using the LED with the LC-1...I think the black side of the LED became grounded -- so basically my wideband was attempting to do a free air calibration...yeah that would screw it up.
Old Apr 18, 2007 | 03:53 PM
iTune's Avatar
Yeah, make sure you get a good free air calibration. Prefereably, take the wideband out of the exhaust stream totally and free air calibrate it. You can do a free air with the WB still installed, but the engine must not of been run for 10 or so hours before you do it. I free air mine all the time(whenever there is a big change in weather/temps). I usually keep it installed, but do it after the car has sat for 12 hours or so. If there is ANY trace gasses in the exhaust, the WB will be off after the calibration.
CJ
Old Apr 18, 2007 | 05:14 PM
klatinn's Avatar
Hi,
Even 12 hrs might not be enough, depending on the exh. system. I've seen systems where it took a week to get all exh. traces to dissipate. The fastest way I found is to just hook a vacuum cleaner (shop vac) to the tailpipe (engine off of course ) and let it run for 5 minutes with the throttle held wide open. Cleans out the exh. system real good. Do NOT try this on a carburated car though. You might launch the vacuum cleaner into orbit.
Regards,
Klaus
Old Apr 18, 2007 | 06:46 PM
supersnow's Avatar
How many pounds are you running?
Old Apr 18, 2007 | 06:56 PM
Jorge T's Avatar
Originally Posted by klatinn
Hi,
Regards,
Klaus
that statement made me laugh!
I'll give the vacuum trick a try.
My LC-1 refuses to work with evoscan...only likes LogWorks2
Old Apr 23, 2007 | 07:47 PM
travman's Avatar
Same here.....I free air calibrated it before installing into the dp and im getting the weird numbers when logging in evoscan, but logworks its fine.
Anybody have a def. fix? maybe I will try calibrating it again in the morning......if thats actually whats even causing it?
ekizenbe
Sep 7, 2016 12:51 PM
EvoXman23
Oct 22, 2013 12:19 PM
RA09
10
Feb 4, 2013 09:19 AM
duffmangt
Site Feedback / Suggestions
Feb 13, 2012 10:56 AM
TIGERJC
AEM EMS
Sep 15, 2010 12:02 AM
