texas tuning
Old Apr 16, 2007 | 08:59 PM
idriveanevo's Avatar
texas tuning
hello, im trying to find a good place to get a tune(i have searched but want better info). i currently have a jester flash and im not very happy with that and i really dont want ecutek and mzm wont use ecuflash for me. so if anybody know where i can get a good tune any info would be greatly appreciated.
Old Apr 16, 2007 | 09:39 PM
ninja808's Avatar
Check in the South Region Forum for a tuner named KevinD he does great work, and it'll be worth your drive.
Old Apr 17, 2007 | 11:25 AM
kevinD? wheres he from?
Old Apr 17, 2007 | 11:27 AM
06 SLOW EVO's Avatar
yea i need to get a tune also, im in houston, where are u?
Old Apr 17, 2007 | 11:32 AM
KevinD's Avatar
dallas area... i've tuned cars from houston, austin, lubbock and witchtaw falls though... so basically all over texas.
i was considering taking a trip down to austin/SA area some weekend in may to tune cars.
Old Apr 17, 2007 | 12:39 PM
i will defntly be getting a tune if you go to austin, i m about an hour from there in waco
Old Apr 17, 2007 | 02:07 PM
jordo's Avatar
Im in houston texas, I tuned my own car using e85..
Old Apr 17, 2007 | 02:12 PM
how much more power would this make and where would i find ethanol?
Old Apr 17, 2007 | 02:31 PM
jordo's Avatar
I have no dynoed yet..
I plan to max the turbo out..
currently the car is running:
Greddy ti 3"
Invidia test pipe
boost controller (22-23psi)
It feels pretty strong, 300-330ish whp..
Next week once I get some time ill install the other pieces.. turn the boost up to 30psi daily... 400ishwhp
there are 3 e85 pumps in houston...
Old Apr 17, 2007 | 05:13 PM
it would be very insensible for me because there are no e85 pumps where im from
Old Apr 23, 2007 | 10:47 AM
Levar's Avatar
Veteran: Army
Greetings from Iraq! To make sure that I'm up to speed, KevinD, what do you require in order to get a tune done? I guess what I'm asking is how does the process work and how much are you charging? I've always thought that you needed a wideband O2 sensor and/or a EMS in order to do tuning. Do you use ECU flash and that's it?
Old Apr 23, 2007 | 12:24 PM
jordo's Avatar
most important just need a wideband
Old Apr 23, 2007 | 12:46 PM
KevinD's Avatar
i have a wideband system i made that i put on your car. it is the zeitronix package, with my own harness to make it easy to put on your car.
the biggest requirement for me is that you have a catback exhaust with a o2 sensor coming out the side. a stock evo 9 has the sensor coming out the top of the cat which makes it much harder to replace with my sensor. i would preffer a test pipe as well, but if need be we can take into account the catalyzed exhaust if you do have a cat on the car.
other then that, i should have no problem tuning it. i do have ECUflash and evoscan/mitsulogger/zeitronix software to log everything with and flash the stock ecu. i charge 200 dollars for a complete custom wideband tune. i do not travel as of yet, but i am thinking of making a drive down to houston/austin/SA area in may with some evo buddies and making a tuning weekend out of it. my prices will be slightly higher though if i travel to cover my expenses.
i will give you all the files, i make of yours so you can review them and save them for your own personal use, or if you want to begin tuning yourself, thats up to you.
you can PM me, email me, or call me if you want to set something up. i am quite busy so it will take a few days/week notice to do a tune especially if you are going to travel to get it done. i want to ensure you get all the time you need in case anything goes wrong, or parts need to be replaced (for example i recommend doing a boost leak test to make sure the tune is exactly on... and this can take 20 minutes, or a few hours depending on how many leaks there are).
Old Apr 25, 2007 | 10:49 AM
Levar's Avatar
Veteran: Army
Great! You have a wideband O2 system. I have the APS turbo-back exhaust system for my VIII without a test pipe. I purchased one a while back only to find out that it needed to be cut in order to fit right. Apparently, when the APS kit was installed, my stock catalytic converter was cut and then welded in order for things to fit. If you're able to do some cutting/welding, I can purchase another test pipe and we can do the entire process. I understand about you not traveling. I don't mind making the drive up north from Austin. It'll be nice for me and my son to get away. I have the ECU flash software as well and I played around with it a bit before I came to Iraq. Yep. Iraq! Are we talking about a tune on the road or on a dyno? I'll do what I can to get the leak test completed beforehand but if I have any issues, could you help me out? I'll have my non-ball-bearing 50 Trim installed with cams and a meth kit by then. Will you still be able to do the tune? Thanks.
cumminsracer14
Dec 2, 2016 02:53 AM
boyvang
May 29, 2015 08:15 AM
06_MR_FTW
Pacific Northwest
11
Jan 30, 2013 08:33 PM
makku
Jan 31, 2003 12:42 PM
