Lean Spool Disable, Before/After
Old May 3, 2007 | 08:54 PM
  #46
iTune's Avatar
Originally Posted by Phenix_fyah
That is high,,,,, in 90 Degree 100% humidty weather i see a max of 100-110' IAT with the HKS RS intake.
Have you logged the IAT's during WOT? If so.....how high did the IATs get during WOT? With the AEM, one particular run, IATs where 86.6 degs before WOT then, as RPMs rose @ WOT, the IATs peaked at 98.6 degs. That was just run #1....
As i continnued to run the car and things got more heatsoaked.....it got proggresively worse, as i expected.
CJ
Old May 3, 2007 | 09:08 PM
  #47
iTune's Avatar
Oh yeah, forgot to add.....i'm not using the stock snorkel or the provided AEM heathsield currently. I wanted to get a accurate reading of IATs using similar setups as most other open element, hard pipe intake systems people are using, as most don't have heat sheilds or re-use the stock snorkel.
I am, however, intrested to see how much of a difference it will make on IATs once i do install the heathseild and snorkel. But for now, i'm leaving them off because of the aformentioned reasons.
CJ
Old May 3, 2007 | 09:26 PM
  #48
Ph3n1x's Avatar
On a Drag run after idling for nearly 3-5 mins before running i saw IAT's 107 Max, that was on 3rd gear before i went to 4th where it started to decrease slightly
Just to correct , the highest ive seen from long idling is 115 or so.
Old May 3, 2007 | 11:51 PM
  #49
3gturbo's Avatar
ecu Perephery Bit 0 disables/enables Lean Spool
Old May 4, 2007 | 07:12 AM
  #50
mrfred's Avatar
Do you mean periphery zone 0xfaa?
Old May 4, 2007 | 08:12 AM
  #51
gunzo's Avatar
Originally Posted by mrfred
I thought the antilag tables were for actual antilag and are not used on the USDM Evos.
https://www.evolutionm.net/forums/sh...d.php?t=246486
This map is used instead.. 2D map
Old May 4, 2007 | 03:00 PM
  #52
3gturbo's Avatar
Yes
ETS Michael
36
Feb 5, 2014 11:44 PM
tephra
289
Jul 20, 2013 05:03 PM
EvoDan2004
Northeast Region
66
Apr 13, 2010 01:46 PM
erioshi
Mar 29, 2010 03:39 PM
ProccoEVO
Southeast Region
249
Nov 15, 2009 10:24 PM
