Want to remove/disable your rear O2 sensor without a CEL? Here's how..
I know there's a software fix for the rear heater CEL.... but for those of us who have removed the front O2 sensor, this thing is still needed. Just purchased one of these from ebay (~$8):
Code:
Description: Mil-Spec, Wirewound Power Resistor. Aluminum housing is chassis mountable to utilize heat sink effect. Standard winding (ERH-10 Model). Molded construction for complete protection from the environment. Part Number: RER65F75R0R Quantity: 1 Piece Resistance Value: 75 Ohm Tolerance: ± 1% Maximum Working Voltage: 265 Volts Wattage Rating: 10 Watts (when mounted, 6 watts in free air) Packaging: Chassis Mount Aluminum Housing Overall Length: 1.375 inches (including leads) Part Marking: 91637 JAN RER65F75R0R 10W 75 OHM 1% (Date codes may vary) Manufacturer: Vishay - Dale
Code:
Code:
ok, i did the rear o2 sim code and it stopped my p0420 CEL (the reason im running it) and i think it stopped me from logging my lt low and mid fuel trims. i switched the rom code back and they started logging again
has anyone had this problem?
tephra v5.10 didn`t work for my CEL, but adding this line to my 96420011 xml
<table name="ECU Periphery0" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
and changing "0x56DA" to "0x56D8" seemed to help))) good luck
I have a software fix for the Rear O2 CEL for the Evo IX 88590015 ROM. The code simulates the rear O2 signal. It should pass any emissions test. It only elminates the rear O2 CEL. If you want to remove the rear O2 sensor from the car, you'll have to do the resistor mod described in the first post. Here are the entries to add to the ECUFlash "88590015.xml" file:
--- start here (do not add this line) ---
<table name="Rear 02 Sim Hook" category="Rear_02" address="c250" type="3D" level="1" scaling="Hex16">
<table name="Code" type="Static X Axis" elements="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="10">
<data>C250</data>
<data>C252</data>
<data>C254</data>
<data>C256</data>
<data>C258</data>
<data>C25A</data>
<data>C25C</data>
<data>C25E</data>
<data>C260</data>
<data>C262</data>
</table>
</table>
<table name="Rear 02 Sim Subroutine" category="Rear_02" address="4a000" type="3D" level="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="20">
<data>4A000</data>
<data>4A002</data>
<data>4A004</data>
<data>4A006</data>
<data>4A008</data>
<data>4A00A</data>
<data>4A00C</data>
<data>4A00E</data>
<data>4A010</data>
<data>4A012</data>
<data>4A014</data>
<data>4A016</data>
<data>4A018</data>
<data>4A01A</data>
<data>4A01C</data>
<data>4A01E</data>
<data>4A020</data>
<data>4A022</data>
<data>4A024</data>
<data>4A026</data>
</table>
</table>
--- end here (do not add this line) ---
Then launch ECUFlash. The stock table data values should be (hex data):
Rear O2 sim hook
E408
D525
6613
D002
400B
0009
A002
0009
0000
D6A2
Rear O2 sim subroutine
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
Change the table data to ("0x" must precede all entries, e.g., 0x0009, 0xD002, etc):
Rear O2 sim hook
0009
0009
0009
D002
400B
0009
A002
0009
0004
A000
DA06
6AA1
6AAD
4A09
DB05
6BB1
6BBD
4B09
4B01
3ABC
DB03
2BA1
000B
0009
FFFF
6A64
FFFF
6B36
FFFF
6A68
Upload the modified ROM to your ECU, and no more rear O2 CELs.
EDIT: Removed some duplicate values.
EDIT (March 15, 2008): Cleaned up the sim subroutine code. Now four lines shorter.
<data>Hex16</data>
</table>
<data>C250</data>
<data>C252</data>
<data>C254</data>
<data>C256</data>
<data>C258</data>
<data>C25A</data>
<data>C25C</data>
<data>C25E</data>
<data>C260</data>
<data>C262</data>
</table>
</table>
<data>Hex16</data>
</table>
<data>4A000</data>
<data>4A002</data>
<data>4A004</data>
<data>4A006</data>
<data>4A008</data>
<data>4A00A</data>
<data>4A00C</data>
<data>4A00E</data>
<data>4A010</data>
<data>4A012</data>
<data>4A014</data>
<data>4A016</data>
<data>4A018</data>
<data>4A01A</data>
<data>4A01C</data>
<data>4A01E</data>
<data>4A020</data>
<data>4A022</data>
<data>4A024</data>
<data>4A026</data>
</table>
</table>
Rear O2 sim hook
E408
D525
6613
D002
400B
0009
A002
0009
0000
D6A2
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
FFFF
Rear O2 sim hook
0009
0009
0009
D002
400B
0009
A002
0009
0004
A000
DA06
6AA1
6AAD
4A09
DB05
6BB1
6BBD
4B09
4B01
3ABC
DB03
2BA1
000B
0009
FFFF
6A64
FFFF
6B36
FFFF
6A68
Okay, I am already simulating the rear o2 sensor but I am getting a code form the heater. Can someone give me a part number, or link to the proper resister to use for the Evolution 8?
Nevermind, the (expletive delete - unnaturally explicit) cut the wires and I have no idea where they are.
Ok i'm new to all of this. I have an 05 Evo and installed a bushur 3in turbo back exhaust. I installed the o2 spacer and cleared the code and it comes on after a cold start. It's throwing a P0137 code. Is there any tutorial or anyhting on how to i guess bypass the rear o2 sensor so it doesnt cause a code. I dont really understand how to do the ecu flash.
Thank You
Thank You
hope someone comes up with a ECU fix for P0137 soon for a 2010 Ralliart... im getting annoyed of the code coming back and would much rather not do a resistor mod to fix it. any input would be great if anyone has solved this for the 09+ Ralliarts
What do i need to get rid of these OBD alarms?
Hi guys,
I have the OBD alarm P136 and P141, after removing the O2 sensor,
my ROM has the ID 88840016.
I guess I need to replace the internal heater (O2) by a resistor about 80Ohm,
about the software mod i'm not so sure.
Do i need to set the FAA bits to 56D8 and will this be enough?
Simon
Simon
O2 removal
My actions so far I have tried to manipulate some bits.
Like (bit 1) for faa => 56DA into 56D8 and also set the heater cel "to disable". All results in disappearing of P136 and P141 and showing up off P125.
No surprise for you guys
<table name="Rear O2" category="Misc" address="faa" type="1D" level="4" scaling="Hex16"/>
<table name="O2 Signal" category="Rear O2" address="fca" type="1D" level="4" scaling="Hex16"/>
<table name="Heater CEL" category="Rear O2" address="2ee1f" type="2D" level="2" scaling="blobbits">
<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>Rear O2 Heater CEL Enable(1)/Disable(0)</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
</table>
<table name="ECU_PEREPHERY2" category="ECUPeriphery" address="fca" type="1D" level="4" scaling="Hex16"/>
</table>
My question now, could the Tephra/Mfred softmod fix also do the trick for ROM 88840016 in combination with 47-82 Ohm resistor?
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
</table>
</table>
