Want to remove/disable your rear O2 sensor without a CEL? Here's how..
I turned on my car about 5 times today since I wrote the fix to the ECU and everything seems to be working great, no CEL here at all! The code would usually come up after the second start after deleting the CEL from the ECU...so far its all good...
Here is my screen shot:
Yeah, I'm thinking that with the exact same stock value of EFDF as Evo 9s, E7DF should work for 8s.
Seems like Periphery2 for ROM ID 96940011 reads the same stock value as above (EFDF) I changed mine to the updated value (E7DF) and will report back later on today...
I have noticed that usually different ROM IDs carry different values for things such as 2 byte load, 2 byte RPM, etc....should I be worried that this code above was for ROM ID 88590015 or are the Periphery codes universal for the USDM Evos?
BTW...I am also using the Rear o2 sim patch for my ROM ID found in this link... https://www.evolutionm.net/forums/sh...d.php?t=333820
I tried this with my 96940011 rom and I'm still getting a CEL. Unfortunately I can't get scantech to work on this laptop for some reason (probably 'cause of vista), so I could have another code being thrown now, but last time I checked I didn't have any other codes.
So let me know if it works for you, I really want this to work!
Thanks mrfred!
