Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Jun 30, 2008 | 11:24 AM
  #331
mrfred's Avatar
Originally Posted by Jack_of_Trades
I totally missed that post, my apologies.
No prob. Just found it odd that no one picked up on it.
Old Jun 30, 2008 | 11:32 AM
  #332
SRT-TO-EVO's Avatar
So has somebody found a way to get this to pass inspection while eliminating the rear 02? I'm so confused with all this electronic talk, it's like french to me.
Old Jun 30, 2008 | 11:46 AM
  #333
logic's Avatar
In simple steps:
  1. wire in a 50ohm 10W resistor into the rear O2 heater circuit to prevent the heater circuit test from throwing a code (or, as Zeitronix suggested, two 22ohm 5W resistors in series)
  2. patch in mrfred's code fix for the sensor test (or just use tephra's ROMs)
  3. drive around for a while
  4. go get tested, pass, go home, have a beverage
I'm not sure what else there is to say. The interesting discussion to me, really, is being able to eliminate step 1 with step 2.
And, if you still have the rear O2 sensor physically wired in (and are just getting a code because of a test pipe), then you can skip all this talk of electronics, and proceed to step 2.
Old Jun 30, 2008 | 12:00 PM
  #334
mrfred's Avatar
I've learned a bit more about how to examine these routines. I might be able to figure this out. Got a few other things going first (namely improve my mpg!).
Old Jun 30, 2008 | 01:13 PM
  #335
scheides's Avatar
EvoM Moderator
Ok, I switched to the 2x 50-ohm 10 watt resistors in a $3 project box from radio shack and it works like a charm! I need to keep an eye on how hot it is because I was only able to get a plastic box with a metal lid.
Old Jun 30, 2008 | 01:45 PM
  #336
Jack_of_Trades's Avatar
Well, as MrFred just pointed out (multiple times apparently,lol) The ECU needs to see between a 1.1 ohm to 80 ohm load to prevent throwing a CEL. The only reason I've ever suggested running 2 50 ohm reisitors in parallel at a 25 ohm load is because on some cars (namely older DSM's) this low of a resistance was required to keep the CEL from coming on. Ideally, you want the highest resistance you can use without throwing a CEL (as close to 80 ohms without going higher) to keep the dissipated heat to a minimum.
Here's the best idea:
This will radiate 66% less heat than (2) 50 ohm resistors in parallel at a 25 ohm load and 33% less heat than a single 50 ohm resistor.
Attached Thumbnails Want to remove/disable your rear O2 sensor without a CEL? Here's how..-heater_load.jpg
Old Jun 30, 2008 | 02:20 PM
  #337
EvoBroMA's Avatar
see jaime! this is exactly why i my made the posts, cause people in here don't have time to learn electronics, and also don't bother reading.
one more time...
Originally Posted by dexmix
If you're using 50 Ohm 10W resistors, using 2 of them in parallel will create more heat, than using a single 50 Ohm.
Old Jun 30, 2008 | 02:23 PM
  #338
I feel bad for ever suggesting it before since the ECU will allow up to an 80 ohm load, which isn't the case with my old DSMs. A 50 ohm would trigger a CEL every time on my DSM's.
Now, if we can only get the OP (PD1) to update his first post regarding the 10K ohm resistor to state it must be between 1.1 to 80 ohms to avoid the CEL.
Old Jun 30, 2008 | 02:30 PM
  #339
EvoBroMA's Avatar
well that's probably the real problem... the OP posted the wrong resistor value. - and still hasn't corrected it. i mean who really wants to read all these posts?
Old Jun 30, 2008 | 02:52 PM
  #340
scheides's Avatar
EvoM Moderator
I was just PM'ing him the other day, I just PM'd him again to get him to update it.
Old Jun 30, 2008 | 02:56 PM
  #341
scheides's Avatar
EvoM Moderator
Freaking sweet! BUT, I'm sick of taking my shiz apart, so question. What could we put in that generates next to zero heat? Even if it was a little bulkier, I'd be fine with it knowing my car isn't gonna go up in flames....
How about 6 50-ohm 10 watt resistors in 3x2 in parallel?
Old Jun 30, 2008 | 03:02 PM
  #342
andrewzaragoza's Avatar
with regards to the heat you could try attaching a small heatsink on the resistor to help dissipate the heat.
Old Jun 30, 2008 | 04:03 PM
  #343
Pd1's Avatar
Pd1
What I originally posted worked just fine for me and many many other people, so I'm not sure it's "wrong."
However, I've updated the original post to include the most recent suggestions.
AOK?
Old Jun 30, 2008 | 04:08 PM
  #344
EvoBroMA's Avatar
AOK?
well according to the ecu code, and basic electronics - the current is way way off the mark?
i have no idea how it worked for anyone, because it surely doesn't work for me, or all of the people that already posted in this thread that it doesn't work.
can anyone on here confirm that your setup works for them more than 15 minutes? all i can think of is that older roms may be more lax with the bounds.
thanks for adding to the post.
Old Jun 30, 2008 | 04:18 PM
  #345
Pd1's Avatar
Pd1
It worked just fine on my IX SE with version 15 ROM for months, so I don't know what to tell you. The resistor didn't get hot, and the CEL never came on. I wouldn't post it if it didn't work.
