Want to remove/disable your rear O2 sensor without a CEL? Here's how..
10 Ohms / 10W ?
hmmm lets see...
P = E*E/R = 14 * 14 / 10 = 19.6W
so you're putting 20W through a 10W resistor. thats a great way to burn it out, or start a fire.
and then you're putting 2 in parallel, which i said previously doubles your heat output, and current draw.
you should really leave the experiments to someone who knows the basics. or use one of the setups that have already been verified to work.
hmmm lets see...
I'm JK
I took it out when I saw it still left a CEL. I just didn't want to leave Radio Shack empty handed.
I'll order one off the internet in the link above.
ok im so confused.
1st let me explain my issues. im up for inspection and i have a rear o2 sensor cel light on.
my question is
is there a way to disable it so i dont get a cel light AND have it able to pass the ready test checks and pass emissions/inspection.??? if so how?? because all this 2 of this and that 50 ohms and stuff is all so confusing for me. and this thread seems to be all over the place. so can someone help me get right to the point on what i need to do to achieve what im looking for..... thanks guys
update. incase it is needed i HAD a evo8 0008 rom and about 2 months ago updated to a 0015 map
my question is
Well, which CEL are you getting? The heater circuit or the signal? A single 50 ohm,10 watt ceremic resistor from radioshack is sufficient to stop the CEL at the very least to get you to pass emissions.
im getting a heater circuit something something system 1 bank 2.....
so if i understand this right your saying to goto radioshack and pick up a 50ohm, 10watt ceramic resister and i will not get a cel and i will be able to pass the ready tests for emissions???
Yea thats what Im thinking Dan lets give it a shot. Do you already have the ECU modded to eliminate the rear O2 (Not the heater but the actual O2 signal). If so lets just try the resistor trick and run it through Scan Tech
no i do not. i have a bone stock 0015 map in. not even a tweek. ill goto radioshack tomorrow and pick a few up. i tend to brake and loose things so. haha
For all who are interested. I found a single 5 watt 75 ohm resistor, +/-5% tolerance for $0.70 HERE. I just ordered one myself and the shipping costs are usually nothing at all so I'd expect for it to be less than $2.00 shipped.
instructions say on page one
Step 2
Disable the Rear O2 routine in the ROM
now i did this and i dont see the ecu periphery0 in the rom. does this not work with a 0015 rom for 03 evos???? or did i do something wrong.
Step 2
- Update the ECUFlash XML file located at: C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ 88590015.xml
using FrontPage or other XML editor to include the following entry so the code ends like this:
<table name="ECU Periphery0" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
</rom> - Open ECUFlash v1.3 and version 15 ROM image. Scroll down to the Misc section and locate the "ECU Periphery0" entry.
- If the value for this entry is "0x56DA," press "=" on your keyboard and type "0x56D8" (without quotes) and press Enter. If the value for this entry is "0x56DB," press "=" on your keyboard and type "0x56D9" (without quotes) and press Enter.
- Save the ROM image and flash your ECU with the new file
holy crap. i dont know what i did but i must of messed up the 88590015 xml....... can someone give me a stock um modded 88590015 xml file so i can copy paste it there to start over. lol.
FYI - Reinstalling ECUFlash will give you your virgin xml files back.
