Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Jul 15, 2008 | 04:25 AM
  #376
gsrboi80's Avatar
Wrong ROM ID Dan thats for a IX. You can just write in the code for the whole MUT table and not have to worry about the propietary BS.
Old Jul 15, 2008 | 10:41 AM
  #377
EvoDan2004's Avatar
O ok. I don't know what I'm doing. Lol. I'm going to re install ecuflash and start over again.
Old Jul 15, 2008 | 04:49 PM
  #378
EvoDan2004's Avatar
i picked up a radioshack 50-Ohm wirewound resister 10watt - 10% tolerance..... its about 1.5 inch long. is this right?? i never seen this stuff before. haha.
Old Jul 15, 2008 | 05:16 PM
  #379
Jack_of_Trades's Avatar
Yeah, looks like this for the most part:
part #271-133
Old Jul 15, 2008 | 06:05 PM
  #380
EvoDan2004's Avatar
part #271-133
your goooooood....... btw thanks for the vid. i just did the v5 and all went well. i think. got to test drive it now.
Old Jul 15, 2008 | 06:59 PM
  #381
Glad to help
Old Jul 15, 2008 | 07:02 PM
  #382
EvoDan2004's Avatar
Glad to help
i really cant take this no more. i never had such issues. now that i reinstalled ecuflash and redid all my patches and mods and installed the v5 i go to flash the new map into the car and the damn 1.3 tatrix wont connect. now what?
Old Jul 16, 2008 | 03:55 AM
  #383
EvoDan2004's Avatar
Well I have no clue what happened. I have never had this problem but I think I fixed it. I first tried reinstalling ecuflash again because I thought maybe the drivers for the tatrix did not get installed. And of course I lost all the v5 patch mods and other stuff I had. And it still did not connect to the car. So I simply just restored the computer to a earlyer date and not I have my 1.29 back and it is connecting to the car no problem. I'm now going to redo all the tephra stuff. Sigh.... thanks to thoughs who's helped me out.
Old Jul 16, 2008 | 04:08 AM
  #384
EvoDan2004's Avatar
O yea. I forgot to tel you guys. To whome wants to know at least.......
Since my stock o2 sensor was shot I cut the plug off it. And I soldered the resister into the 2 black wires of the plug and then just simply pluged it into the factory plug in the car. But I let the resister stick outside the hole so I don't burn her to the ground because I here this little guy gets hot. Lets hope this trick works.
Old Jul 17, 2008 | 06:38 AM
  #385
tephra's Avatar
yeah should be good
I just run my stock rear 02 sensor, as I cant be bothered worrying about the resistor ...
Old Jul 17, 2008 | 06:50 AM
  #386
EvoBroMA's Avatar
Originally Posted by tephra
yeah should be good
if i wasn't so lazy to get a second bung welded into my test pipe, i would do the same
Old Aug 10, 2008 | 12:38 PM
  #387
krazykorean84's Avatar
Just wanted to share my experience with this mod so that maybe it will eliminate some confusion about the different resistors.
The 10k ohm resistor does work when you disable the rear O2 routine in your rom using step 2 in the beginning of this thread.
The 10k ohm resistor will not work if you try to use it with one of Tephra's mod patches.
You must use a resistor with a resistance between 1.1 and 80 ohms to have a proper load for the heater circuit when using either step 2 in the beginning of this thread or when using one of Tephra's mod patches.
You could use a 50 ohm 10W, a 75 ohm 5W, or even better a 75 ohm 10W. I found a hollow 75 ohm 10W resistor on ebay which has been working great for a few weeks now and does not get hot at all.
Old Aug 10, 2008 | 02:17 PM
  #388
But I was pretty sure that Tephra borrowed the same routine that MrFed created? Tephra has the rear O2 delete in his patches.
Old Aug 10, 2008 | 04:21 PM
  #389
Wiznaz's Avatar
My 75 ohm 5W still trips the CEL at start-up because I think it takes too long to heat up. Evoscan shows the Heater Circuit at 20% when the CEL comes on.. once the car is warmed up and the resistor is piping hot, I can clear the code and it won't come back ever again until everything cools back off. It can be quite frustrating though.
Old Aug 10, 2008 | 05:07 PM
  #390
A resistor doesn't change value enough from cold to hot to have any effect. I have been using a 75 ohm 10 watt resistor for quite some time now, no issues. Get a better resistor or check your connections. What is the tolerance on your 75 ohm resistor? It has to be 5% or 1% to stay within the acceptable range that the ECU requires.
