Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Apr 6, 2008 | 10:12 AM
  #226
mitsuboost30's Avatar
Still waiting on the CEL fix to completely eliminate the O2!!
Old Apr 10, 2008 | 03:56 PM
  #227
Oettinger's Avatar
10kohm/.25 amp resistor is a fake. . Other solution using resistors??
Old Apr 10, 2008 | 06:25 PM
  #228
tephra's Avatar
apparently 2x 100Ohm/10W in parralel should work (for a combined resistance of 50ohm)
Old Apr 12, 2008 | 10:46 AM
  #229
Oettinger's Avatar
Ok! Thanks, other problem... one solution for P0125 in evo VIII?? my Min coolant in ecuflash is "0".
Old Apr 12, 2008 | 05:50 PM
  #230
Jack_of_Trades's Avatar
Get two 100 ohm 10 watt resistors from radioshack and twist the ends together so they are in parallel with each other(this makes them into a 50 ohm 10 watt resistor basically). Connect them between the heater wires. Be warned, they do get awfully hot.
Old Apr 13, 2008 | 12:11 AM
  #231
tephra's Avatar
P0125 is (i think) incorrect, some ROMID's have P134 (i think) which is something like "rear 02 no activity" which makes MORE sense than P125.
your best bet would be not to disable the rear02 using the FAA bit, but use the rear02 simulator instead
Old Apr 13, 2008 | 05:40 AM
  #232
Oettinger's Avatar
Simulator-tephra for my 96530006 rom (evo viii)?? where!!!
Old Apr 13, 2008 | 07:02 AM
  #233
tephra's Avatar
v5 thread bro
Old Apr 13, 2008 | 01:04 PM
  #234
Oettinger's Avatar
v5 thread bro
Very thanks!!
Old Apr 13, 2008 | 06:31 PM
  #235
EvoBroMA's Avatar
10K .25W seems to work for me?
edit:or not. going to try the 50 Ohm 10W
Old Apr 14, 2008 | 08:52 PM
  #236
andrewzaragoza's Avatar
i did what jack of trades said 2 100ohm/10w resistors in parallel. it seem to be working fine so far and the heat is very minimal.
update: well im in a long drive right now and it seemed to work the first 2 hrs but when i stopped in a rest area and then started driving again i got the cel. used scan tech and got 2 code: P0133: Heated Oxygen Sensor Circuit Slow Response & P0136: Heated Oxygen Sensor Circuit
cleared the code. i guess i could try a different resistor. any ideas?
Old Apr 19, 2008 | 08:27 PM
  #237
any ideas? has this happened to anyone?
Old Apr 19, 2008 | 10:55 PM
  #238
Oettinger's Avatar
good solution for evo-ix is ecuflash tutorial in this previews pages.
Old Apr 20, 2008 | 06:11 AM
  #239
are u referring to mfred's ecu changes? i have done all of that. i was thinking maybe a 50 ohm is too much resistance for the ecu. ill try a different resistor.
Old Apr 20, 2008 | 07:18 AM
  #240
I suggest running two 50ohm, 10 watt resistors from RadioShack in parallel to create a 25ohm resistor. The current is split between the two resistors to minimize how hot they'll get. Each resistor will have around 4 watts of power being dissipated through it, less than half of its maximum rating.
