Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Mar 3, 2008 | 06:08 AM
  #166
nothere's Avatar
mrfred,
If the car is never in closed loop does the ecu still question the o2 sensors if they are "on board"?
I just realized my fuel trims are completely shut down now that I have a version of JB's open loop economy settings.
Old Mar 3, 2008 | 06:23 AM
  #167
mrfred's Avatar
Good question. I don't know. I'll have to take another look to get tha answer for you.
Old Mar 3, 2008 | 07:08 PM
  #168
tephra's Avatar
hey guys - will a 10kohm/.25 amp (or is it watt?) resistor get HOT?
Old Mar 3, 2008 | 11:10 PM
  #169
al\lupo's Avatar
No, with a 10k on 13 V you will get barely 1-1.5 mA of current, a value too low to keep the ecu happy. Ecu needs at least 0.2 A, so a 47 ohm 10W will be ok (47 ohm on 13 V will get less than 4 W of power).
Old Mar 3, 2008 | 11:17 PM
  #170
Jack_of_Trades's Avatar
I found it odd that you could get away with only a 10K ohm resistor as well. Thats not even CLOSE to simulating the original reisistance of an O2 sensors heater circuit. Most NB heater circuits start out with lower resistance and raise as the heahter reaches operating temp which is in the 4-9 ohm range. I'd be interested to find out just how high of a resistance is enough to satisfy the ECU into thinking there is a proper load on the heater circuit.
I personally would recommend using two 100 ohm/10 watt resistors for $3.98 from Radio Shack wired in parallel to minimize the heat dissipation from each resistor. That way you wont worry so much about the resistors getting hot.
Old Mar 4, 2008 | 01:18 AM
  #171
tephra's Avatar
Well heat is my main concern
I guess ill test the 10k first I am hoping the circuit just needs to be closed for the ECU to be happy, rather than looking for a specific voltage/current/resistance...
Old Mar 4, 2008 | 02:39 PM
  #172
If thats all it needs, thats very nice indeed.
Old Mar 13, 2008 | 05:48 PM
  #173
Oettinger's Avatar
Some solution for my evo viii (Ecu 96530006)? Only solution is for evo IX?
Thanks!
Old Mar 13, 2008 | 06:19 PM
  #174
MR Turco's Avatar
Originally Posted by mrfred
Change the table data to ("0x" must precede all entries, e.g., 0x0009, 0xD002, etc):
Rear O2 sim hook
0009
0009
0009
D002
400B
0009
A002
0009
0004
A000
0004
A000
Are there 2 too many values? i assume the first two 0009s are not necessary?
Old Mar 13, 2008 | 09:54 PM
  #175
mrfred's Avatar
Sorry about that. Remove the duplicate 0004 and A000 at the end. I fixed the original post.
Old Mar 14, 2008 | 05:00 AM
  #176
MR Turco's Avatar
No problem, thank you for the mod. It is cheaper then a new rear o2 sensor.
Old Mar 14, 2008 | 05:50 AM
  #177
Oettinger's Avatar
And for evo viii???
Old Mar 14, 2008 | 05:55 AM
  #178
MR Turco's Avatar
Originally Posted by Oettinger
And for evo viii???
Don't ask for 8 or 9 support as for specific rom version support.
Old Mar 14, 2008 | 06:53 AM
  #179
mrfred's Avatar
And for evo viii???
tephra is incorporating it in his feature ROMs. Should be available in maybe a month or two.
Old Mar 14, 2008 | 07:08 AM
  #180
l2r99gst's Avatar
mrfred,
Depending on what tephra finds out about the lack of space in the 96940011 ROM, he may not be releasing a v5 for this ROM.
If not, would you mind explaining to me (over PM if you wish), what exactly your patch is doing and if you have looked at an VIII ROM or not? I wouldn't mind searching for the code in the 96940011 ROM and making the patch myself, but I wanted to make sure I understood what you were doing first before I made an attempt at it.
Eric
