Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Apr 20, 2008 | 07:10 PM
  #241
andrewzaragoza's Avatar
Originally Posted by Jack_of_Trades
I suggest running two 50ohm, 10 watt resistors from RadioShack in parallel to create a 25ohm resistor. The current is split between the two resistors to minimize how hot they'll get. Each resistor will have around 4 watts of power being dissipated through it, less than half of its maximum rating.
thanks! ill try this out and update you how it works out for me.
Old Apr 21, 2008 | 06:18 AM
  #242
merkzu's Avatar
I had a resister on my heater circuit for about a year, it just recently burned out (I had it under the car). The place I bought it from doesn't sell O2 simulator stuff anymore because the EPA harassed them, but they told me to use a 40ohm-25watt resister from digikey.com, part number RHC-40-ND as a replacement.
Old Apr 21, 2008 | 06:42 AM
  #243
have you replaced it already? how is it working so far?
Old Apr 21, 2008 | 07:54 AM
  #244
merkzu's Avatar
I just ordered it this morning, I'll post up when it comes in and I test it out
Old Apr 25, 2008 | 08:10 PM
  #245
merkzu's Avatar
Installed this today, seems to be working so far. My heater +12v and ground wires are both black.. I am using wires from the O2 sensor side of the plug though, maybe the colors are different there. I ran some errands and it was cool to the touch when I got home..
Old Apr 25, 2008 | 08:22 PM
  #246
phenem's Avatar
Could you take pictures of how you hooked it up?
~Z
Old Apr 26, 2008 | 11:34 AM
  #247
merkzu's Avatar
~Z
I can't really get a good pic without taking my seat out, but there is a plug where the rear O2 sensor connects to the car wiring. On the O2 sensor side of that plug, there are two black wires. I have them connected to the resistor
This is from a post in the how-to section on installing an O2 sim:
List of wires from the o2 Plug from the car on the o2 sensor side. Do not cut the wires on the car wiring harness side only on the 02 sensor side becuase it can be replaced very easily. The correct plug is BLACK.
1.Solid Black
2.Solid Black
3.Solid White
4.Solid Blue
The two black wires are Heater 12v and Heater ground. I cut off the O2 sensor since I don't use it at all
Old Apr 27, 2008 | 07:54 PM
  #248
today i drove around an hour and i got a code 133. this happened using 2 50 ohm 10 watt resistor in parallel. i noticed the cel comes on after driving a long time. if i just drive for a few min do not get the cel. i guess the resistor is heating up too much when driving for over an hour.
Old Apr 27, 2008 | 07:56 PM
  #249
how is this working out so far for you?
Old Apr 27, 2008 | 08:17 PM
  #250
tephra's Avatar
133 = Oxygen sensor slow response..
so either the code is buggy OR its not a heater problem...
Which mod have you done to remove the rear02 andrew?
Old Apr 28, 2008 | 06:46 AM
  #251
Here is what i did. i used mfred's table changes (post #148) since i have IX then removed the rear o2 and placed the resistor in place. Did i miss something out? I removed the rear o2 since i used the bung for my wideband.
thanks.
Old Apr 28, 2008 | 06:47 AM
  #252
mitsuboost30's Avatar
How is it working out for you? any problems heat anything?
Old Apr 28, 2008 | 07:42 AM
  #253
mrfred's Avatar
P0133 = *front* oxygen sensor slow response.
Old Apr 28, 2008 | 08:07 AM
  #254
Oh ok. well so i guess my resistor and your code is working. i now know y it is showing up. its because im using my zeitronix's narrowband simulator. I did this since i adjusted my switching point. i guess the wideband takes longer to warm up causing the slow response. does anyone know how to adjust the treshold for this slow response error?
Old Apr 28, 2008 | 08:28 AM
  #255
merkzu's Avatar
Still working fine, drove it around this weekend and to work this morning. Doesn't get hot at all
