Evo anti-lag ECU disassembly
Old Mar 16, 2008 | 02:57 AM
  #226
al\lupo's Avatar
Originally Posted by NineWorks
I'm afraid I'm still having xxxx with the above 88840016 air injection table...?
You are probably missing this scaling:
Code:
<scaling name="TimeSecByte" units="s" toexpr="x/10" frexpr="x*10" format="%.1f" min="0" max="25.5" inc="0.1" storagetype="uint8" endian="big"/>
Old Mar 16, 2008 | 03:19 AM
  #227
agron25's Avatar
Originally Posted by al\lupo
No, looking in code this is better:
Code:
<table name="ALS Air injection time" category="ALS" address="4e3a" type="2D" level="1" scaling="TimeSecByte">
	<table name="RPM" address="77ae" type="X Axis" elements="9" scaling="RPM"/>
</table>
BTW, in 88840016 this tables are defined but not referenced anywhere.
i find
code adress 77ae
RPM
3000
3500
4000
4500
5000
5500
6000
6500
7000
Old Mar 16, 2008 | 03:20 AM
  #228
taavisev's Avatar
so it means that what ever we but in there it doesnt work anyway?
Old Mar 16, 2008 | 03:40 AM
  #229
al\lupo's Avatar
First of all in 88840016 and 17 the ALS routines are missing. The tables are defined but not used at all.
More over I looked to a similar ROM where ALS routines are defined; the correct axis address for air injection time is 7792 (RPM from 2000 to 6000).
@ taavisev: you are missing the scaling definition. Complete definition to add in XML is:
Code:
<table name="ALS minimum vehicle speed to trigger" category="ALS" address="1e12" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="ALS" address="1e14" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="ALS" address="1e16" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="ALS" address="1e18" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="ALS" address="1e1a" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="ALS" address="1e1c" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="ALS" address="1e1e" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="ALS" address="1e20" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="ALS" address="1e22" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="ALS" address="1e24" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="ALS" address="1e26" type="1D" level="1" scaling="TimeSec"/>
	<table name="RPM" address="7792" type="X Axis" elements="9" scaling="RPM"/>
</table>
But this tables are totally useless in our ROM
We miss not only the SAS hardware, but also the control rutines in ROM.
Old Mar 16, 2008 | 03:44 AM
  #230
BarryC's Avatar
Code:
</table>
I dont think those control routines are in any of the roms
no matter what I set the ALS parameters to it has absolutly no effect on the car,
Old Mar 16, 2008 | 03:50 AM
  #231
taavisev's Avatar
i get it right and numbers are ok now! but if there is no control rutines what can we do then!
we have here EDM N class rally cars and all of theme have sas hardware on! but i dont know whats going on in the ECU and what ID they use! I have to talk with my guy ho is owner of the rally cars building shop... maybe he can help and let me see in the car ECU.
  #232
al\lupo's Avatar
In 88580013 (AUDM) are referenced in a routine called from the main engine control loop.
Old Mar 16, 2008 | 04:00 AM
  #233
BarryC's Avatar
is there any chance you could look into this rom and see if they are referenced in a main routine anywhere please,
File Type: zip
Old Mar 16, 2008 | 04:46 AM
  #234
al\lupo's Avatar
If you mean the table named "Boost Enhancement (Anti-lag) Table" yes, it is referenced - but I can not tell how it is used, if anyone have disassembled this ROM probably knows the variables.
Old Mar 16, 2008 | 04:49 AM
  #235
agron25's Avatar
Code:
</table>
yes
the address RPM 7792 is good
thank
Old Mar 16, 2008 | 10:42 AM
  #236
NineWorks's Avatar
Anyone can post these ALS adresses for JDM VII ROM 99860002 or 90550001 ?
The first one is a std JDM version ROM (car fitted with SAS), the second is a Ralliart ROM...
The ALS routine should be called at least !
Old Mar 16, 2008 | 10:51 AM
  #237
cossie1's Avatar
This is for 905500001 rom.
Not tested the 99860002 rom yet, as non of my roms have that id.
<scaling name="RPMstatbyte" units="units" toexpr="x*31.25" frexpr="x/31.25" format="%.0f" min="0" max="11000" inc="1" storagetype="uint8" endian="big"/>
<scaling name="Timesecbyte" units="s" toexpr="x/10" frexpr="x*10" format="%.1f" min="0" max="25.5" inc="1" storagetype="uint8" endian="big"/>
<table name="ALS minimum vehicle speed to trigger" category="Turbo" address="2210" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="Turbo" address="2212" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="Turbo" address="2214" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="Turbo" address="2216" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="Turbo" address="2218" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="Turbo" address="221a" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="Turbo" address="221c" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="Turbo" address="221e" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="Turbo" address="2220" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="Turbo" address="2222" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="Turbo" address="2224" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Air injection time" category="Turbo" address="49e6" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="569a" type="X Axis" elements="9" scaling="RPM"/>
</table>
Old Mar 17, 2008 | 12:09 AM
  #238
al\lupo's Avatar
</table>
Checked, in 90550001 these tables ARE referenced.
Old Mar 17, 2008 | 03:35 AM
  #239
Youngsyr's Avatar
My tuner friend thinks he's found how to get the ALS working. Hopefully his "fix" will be tested today (within the next 8 hours) and we should have some results tonight (in about 12 hours).
Old Mar 17, 2008 | 04:08 AM
  #240
BarryC's Avatar
good stuff
