ECU flash error: no known code
Old May 10, 2007 | 11:49 AM
Dennis F's Avatar
When I try to read the rom this is all I get.
not
As far as I know the drivers are ok and I do not have any other program running.
Looks like this,
[00:04:42.966] Version 1.30.1095
[00:04:42.976] 8 memory models read.
[00:04:48.484] 145 ROM metadata models read.
[00:04:48.494] checksum module "subarudbw" loaded.
[00:04:48.494] flashing tool "wrx02" loaded.
[00:04:48.494] flashing tool "wrx04" loaded.
[00:04:48.494] flashing tool "sti04" loaded.
[00:04:48.494] flashing tool "sti05" loaded.
[00:04:48.494] flashing tool "mitsukernel" loaded.
[00:04:48.494] flashing tool "mitsukernelocp" loaded.
[00:04:48.494] flashing tool "mitsubootloader" loaded.
[00:05:16.374] sending init sequence 1 (0001)
[00:05:19.639] sending init sequence 1 (0003)
[00:05:22.924] sending init sequence 1 (FFFF)
[00:05:25.668] no response to any known code
What do I need to do, or what did I do wrong?
Old May 10, 2007 | 11:51 AM
RnRjames's Avatar
Check All Connections. Make Sure You Are Selecting The Right Vehicle
Old May 10, 2007 | 12:03 PM
Dennis F's Avatar
I am confident the connections are ok and I picked the right car.
When I try to read the image, I hear a couple clicks under the dash and if I wait long enough, after the SES light goes off, it will go back on when I try to connect.
Evoscan works fine as well. I tried to reinstall ecuflash after removing it and nothing changed. I am using v1.30.
Old May 10, 2007 | 12:11 PM
newbieEVO8's Avatar
Has this car been tuned before?
If so, they have locked you ecu and you will not be able to read or right to it until you go to www.aktivematrix.com and get the unlocker software.
You will need to register there and go to the downloads section and go to the ecuflash addons section.
G/L
Old May 10, 2007 | 12:18 PM
Dennis F's Avatar
Yes, it was flashed from the previous owner. I don't know who did the flash though. Thanks for the tip though.
Old May 10, 2007 | 12:22 PM
Mellon Racing's Avatar
sounds familiar doesn't it Brad.. unfortunately most tuners lock you out of your own ECU... lovely aint it
p.s. I don't do that, it's your ECU, not mine.
Old May 10, 2007 | 12:57 PM
Dennis F's Avatar
So what do I do now?
I tried that unlocker but I just don't get it. I DL'd the program it says to use and when I tried to open the unlocker it asks what program I want to use to open it with.
The framework program is in my laptop but I don't have an icon to choose it.
I am really starting to get pissed off.
Old May 10, 2007 | 01:06 PM
what's the file extension..I forget?
Old May 10, 2007 | 02:12 PM
Dennis F's Avatar
I dunno. I am really good with electrical parts, alarms, navs and other accesories like that but don't know computer stuff to well.
I do know I installed .netframework 1.1 to use evoscan and did the same setup, that works fine.
Now the unlocker is asking for which program to use to open it up. I am lost.
Old May 10, 2007 | 02:47 PM
hit me up on AIM tonight Mellon91TT and I'll walk ya through it
Old May 12, 2007 | 12:37 AM
SICK9's Avatar
The files must be still in rar format.
so you'll need winace or any program that opens rar files.
then use it to extract the files to wherever you want, desktop, etc..
then all you do is start ecu unlocker and let it run in background then open up ecuflash. voila. you are in..
Just went through all this.
GL, it's easy..
Old May 12, 2007 | 04:34 AM
Dennis F's Avatar
I used rar and it did work perfectly.
All set now.
Old May 12, 2007 | 02:51 PM
newbieEVO8's Avatar
So familiar that I even remembered seeing all the stuff on your laptop that he listed in his post.
Thanks for helping me out.
Old May 12, 2007 | 10:07 PM
you're welcome, now quit whipping my butt at the autox
monkeyevo
Aug 2, 2011 01:52 PM
DSMolition
Jul 5, 2011 06:25 AM
GBAILEY472
Jun 24, 2009 08:25 AM
staatz
Nov 13, 2007 06:27 PM
