my a/f & timing
Old May 16, 2007 | 07:28 PM
  #31
TTP Engineering's Avatar
Originally Posted by nothere
speaking of trend trims and colors can some one tell me why a tuner keeps the negative timing in the very low rpm high load areas.
it would difficult to hit those cells or get close to them.
Why change them to positive then if you cannot hit them?
Old May 16, 2007 | 07:33 PM
  #32
Mellon Racing's Avatar
What RPM and Load in particular are you referring to?
  #33
ddubdb3's Avatar
well besides the cool colors i put the stock map on....wow big difference the car definatly doesnt pull as hard as it used to.. im thinkin im goin to get one of those send your map in let them flash it deals. until i can get it dyno tuned who do you guys suggest??
Old May 16, 2007 | 07:34 PM
  #34
nothere's Avatar
good question but more strange is changing the negative values. as if they were justifiable.
Old May 16, 2007 | 07:39 PM
  #35
Its obvious 180-260 load to 750rpms.
Old May 16, 2007 | 07:40 PM
  #36
It means the tuner doesn't know what they are doing and to turn around and run if you see this.
Old May 16, 2007 | 07:41 PM
  #37
We have this service available when you are ready.
There is an eflash poll here on some of the most popular proven tuners:
https://www.evolutionm.net/forums/sh...3&goto=newpost
Old May 16, 2007 | 07:43 PM
  #38
that's what I figured but didn't want to assume he was referring to the obvious. some people leave negative values in the 280/3000 rpm range
Old May 16, 2007 | 07:48 PM
  #39
Negative 1-3 degrees at peak torque at 280-300+ is normal and acceptable for certain tunes.
ddubdb3
West Region
78
Dec 29, 2007 11:28 AM
ddubdb3
May 13, 2007 11:58 PM
ddubdb3
Mar 12, 2007 12:01 PM
ddubdb3
Mar 4, 2007 04:27 PM
ddubdb3
14
Dec 25, 2006 10:45 PM
