Load + RPM scaling...
Old May 25, 2007 | 10:50 AM
  #31
mplspilot's Avatar
Originally Posted by razorlab
No it actually reduces timing beyond the max load column. I've even seen a strange anomaly where it will actually knock sometimes if brought beyond the max load, rescale the load columns, no more knock.
Good info
Old May 25, 2007 | 07:47 PM
  #32
Jeff_Jeske's Avatar
If I were to set the last column at 340 so the cells would jump from 240 to 340 kinda like the rpm jump from 7500-11000 on the stock map...... would that cause any problems other than a somewhat block tune in the higher load cells?
Old May 26, 2007 | 12:04 AM
  #33
RazorLab's Avatar
Yes you could do that, but I would recommend rescaling the rom a bit better since it will prepare you for later mods as well.
Old May 26, 2007 | 05:26 AM
  #34
Jeff_Jeske's Avatar
My high end is all fairly close and conservative especially since I dont see those load unless on alchy and race gas. I simply don't like losing the lower rpm and partial throttle resolution as the car sees more of that than anything else.
InsaneSpeed
Apr 24, 2011 02:37 PM
electricevo
81
Dec 11, 2007 09:55 AM
electricevo
56
Jul 24, 2007 10:02 PM
electricevo
Jun 18, 2007 09:00 AM
electricevo
Jan 14, 2007 07:39 PM
