First Log on my Evo IX
Old May 27, 2007 | 06:06 PM
nj1266's Avatar
Originally Posted by Evo_Kid
Oh yeah, later IXs never really hit factory boost (20.3lbs~16lbs)
When I did my log humidity was @ 60%. I have discovered that high humidity lowers boost. One time I logged with 80-90% humidity and lost 1.5 psi of boost. I thought I had a boost leak. Then I logged the next day when humidity was in the 40s and regained the lost boost.
Had I been logging my 9 under sub 40% humidity, I would have logged the 20.xx stock boost.
Old May 27, 2007 | 06:10 PM
Evo_Jay's Avatar
Originally Posted by nj1266
So I do this by changing the Boost Enhancement (Anti-Lag) Stop RPM from 4531 to 7800 rpm? What impact would that have on the AFR from 4531 rpm on? I suspect the AFR will become leaner. Correct?
A lil harder then that. You have to change the addresses of the maps, then change the settings.
Old May 27, 2007 | 06:24 PM
RazorLab's Avatar
No, here is a quick and dirty way to add control of it, in ecuflash, right-click on the left column under Fuel and select "new map" and follow this screenshot:
Old May 27, 2007 | 06:58 PM
mrfred's Avatar
Read this post:
https://www.evolutionm.net/forums/sh...57#post4364757
If you want to see lean spool start/stop values, go into your 88590015.xml file, and add these items:
<table name="Lean Spool Start RPM" address="1281"/>
<table name="Lean Spool Stop RPM" address="1285"/>
Then go into your evo9base.xml file, and add these items:
<table name="Lean Spool Start RPM" category="Turbo" type="1D" scaling="RPMStatLimit8"/>
<table name="Lean Spool Stop RPM" category="Turbo" type="1D" scaling="RPMStatLimit8"/>
There is another thread on lean spool that is worth reading:
https://www.evolutionm.net/forums/sh...d.php?t=273119
Old May 29, 2007 | 04:40 PM
nj1266's Avatar
Originally Posted by razorlab
Pretty normal. The stock 9 tapers so much up top and runs a bit rich, not as rich as 8's but rich.
I installed two bungs on my HFC. One for the stock narrow band at the tail of the HFC and one for the wideband on the mouth of the HFC. Today I logged the AFR. Boy is this car running rich stock. This is richer than my 8 was, but I only logged my 8 with a TBE. I never logged it stock. Here are the 4 logs averaged. I suspect that the knock that I was getting up top is due to running rich. You can knock when you run rich.
The car is below 11 starting @ 4000 rpm What the hell was thinking tuning the car like this.
Old May 29, 2007 | 04:49 PM
RazorLab's Avatar
I've seen 8's run richer than that.
Old May 29, 2007 | 09:08 PM
C6C6CH3vo's Avatar
They were thinking of a way to allow conumer joe to run 89 octane and use timing retard to control knock threashold. Totally impossible with a car tuned with a a powerful AFR and with even less than optimal timing. I bet Car is about 65% undertuned from factory
How in the hell did Razorlab figure that method of LS dis?
Old May 29, 2007 | 09:44 PM
mrfred's Avatar
Does your wideband AFR data represent a completely stock ROM (no mods to lean spool, AFR map or anything else)?
Old May 29, 2007 | 09:48 PM
nj1266's Avatar
Yes. I only have the 2byte load and JDM MAP sensor patch.
Old May 29, 2007 | 09:58 PM
mrfred's Avatar
Interesting. Seems that with lean spool enabled, the actual AFR runs about 1 point richer than the AFR in the fuel table. Would be interesting to see how close actual AFR is to the AFR table when lean spool is disabled.
Old May 29, 2007 | 10:22 PM
C6C6CH3vo's Avatar
Interesting. Seems that with lean spool enabled, the actual AFR runs about 1 point richer than the AFR in the fuel table. I knew that lean spool leans out the AFR by about 1 point, but I wasn't sure how close actual AFR to the AFR in the table. Would be great if you got another log with lean spool disabled.
My before and after log files showed a little more than 1 point richer after where it steadily declined to nothing where it stopped at end of spool . For that log it was from 3500RPM to 4100 rpm . Not sure if it's RPM related or spool (VE, TPS, MAF open/closed loop) related, or both - for I changed the fuel map shortly after
Old May 29, 2007 | 11:15 PM
RazorLab's Avatar
Say what?
Old May 30, 2007 | 05:40 AM
mrfred's Avatar
Say what?
Yeah, that took me a few minutes too. He's wondering how you came up with that method to disable lean spool.
Old May 30, 2007 | 05:56 AM
Evo_Jay's Avatar
I've seen it done like that some where else on here, because thats how I hard it at first on my ROM. Then I changed it to the way the how-to says to do.
Old May 30, 2007 | 01:04 PM
nj1266's Avatar
I just want clarification that the method that you outlined has nothing to do with the lean spool enable/disable. Correct. The intent of this method is to control the extremely rich AFR that the Evo 9 encounters past 7000 rpm. Is that correct?
