Help!!!!!!!!!!
Old Jun 4, 2007 | 05:11 PM
Slava's Avatar
I probably might help u but it depends if u have same ECU id as me i have 94170008
so i can disable immobilizer for it
Old Jun 4, 2007 | 05:15 PM
redevoboy's Avatar
Originally Posted by urBan_dK
Did you load your stock map for a back-up first?
If so, you should be able to figure out your ECU ID. It's possible you loaded a map for the wrong ECU ID onto your car.
This is different from the immobilizer code. It specifies where each map exists in the memory. If you loaded an image where these locations were wrong, it may not even start.
Bingo! Your car WILL NOT start without the right ECU ID. I hope you know what that is, or have your ecu image saved. If not there goes LOTS of money to the stealership.
Care to elaborate on how to disable the immobilizer? I doubt he has the same ECU id as you.
Old Jun 4, 2007 | 05:16 PM
sharkm87's Avatar
is there an option in ecu flash to disable it?
Old Jun 4, 2007 | 06:45 PM
I Kill Suckers's Avatar
is it badd to disable the immobolizer?
Old Jun 4, 2007 | 06:51 PM
sharkm87's Avatar
...i guess all it does is "recognize" your key when you try to start
Old Jun 4, 2007 | 06:56 PM
no need to be sarcastic....im in need of help not sarcasm
Old Jun 4, 2007 | 07:11 PM
wheredo u find ur ECU ID
Old Jun 4, 2007 | 07:13 PM
sharkm87's Avatar
i wasn't being sarcastic, i was just saying that i would assume its not important since it plays no major role.....i'll try to be more straight forward
Old Jun 4, 2007 | 07:14 PM
cfdfireman1's Avatar
"wheredo u find ur ECU ID"?
in the rom that was in your car when it ran. you saved that right?
Old Jun 4, 2007 | 07:17 PM
sorry for taking it the wrong way.....
No i didnt say the stock ROM, i have went over the already....I ****ED UP, i kno...But there has to be a way for me to get my car running
Old Jun 4, 2007 | 07:18 PM
sharkm87's Avatar
i belive he flashed over that mistakenly.
Old Jun 4, 2007 | 07:22 PM
no
You may have gone over that in your mind but not in this post read it again.
Tow to dealer is in your future.
Old Jun 4, 2007 | 07:26 PM
thats it...juss bring it to the dealer......there is no way a tuner on here can help me out...wut about if i get a reflash?
Old Jun 4, 2007 | 07:34 PM
TTP Engineering's Avatar
Congratulations, you need to purchase a new ECU from the dealer as you overwrote your immobilizer code and without it, you will not be able to start your car.
The new ECU will sync itself with your immobilizer from my best information and you will need to download the flash off your new ECU, save it so this does not happen again.
Old Jun 4, 2007 | 07:37 PM
anyone kno how much a ECU usually goes 4
