Help!!!!!!!!!!
Old Jun 5, 2007 | 01:48 PM
  #46
I Kill Suckers's Avatar
how much would u want for it?
Old Jun 5, 2007 | 01:56 PM
  #47
sharkm87's Avatar
Originally Posted by mplspilot
That's cause you shouldnt be playing with your ECU.
Set it to "0xffff"
did that work OP?
Old Jun 5, 2007 | 01:58 PM
  #48
nope
Old Jun 5, 2007 | 02:03 PM
  #49
grayw's Avatar
In which case you have the wrong ECU image, as said earlier in the thread.
You need to find other USDM images and try to find the correct one for you car.
You will also need to set the imob code to * in these also.
For your info, the ecu id you sent me was 96940011.
Old Jun 5, 2007 | 02:06 PM
  #50
ok so there are 96940011 different ones...Or are there just a couple...Also if i find someone with a stock Ecu will that get my car to start if i install it.
Old Jun 5, 2007 | 02:14 PM
  #51
grayw's Avatar
There are more than one version of the ECU, each is give an internal id code.
The one you sent me was 96940011, not sure how many different ones are used on USDM cars, not loads though.
If you can get other stock roms from the same year and model EVO, you can try these, but as said earlier.
Old Jun 5, 2007 | 02:15 PM
  #52
if i get a stock ECU and instill it will that fix the problem also?
Old Jun 5, 2007 | 02:16 PM
  #53
sharkm87's Avatar
if thats the case, why is he uanble to get it to work with the current ecu rom loaded?
Old Jun 5, 2007 | 02:18 PM
  #54
grayw's Avatar
Only if you set the imob code, and the ECU internal ID was the same as the one you flashed over.
You can't just plug it in
Old Jun 5, 2007 | 02:23 PM
  #55
grayw's Avatar
Some model / year evo ECU's have maps stored in different locations within the rom. Therefore making them non-interchangable.
You need the same rom image, that was originally in the ECU, identified by the internal ID no.
Old Jun 5, 2007 | 02:25 PM
  #56
but u can only tell that threw the stock rom witch i dont have anymore rite...so im screwed
Old Jun 5, 2007 | 02:32 PM
  #57
grayw's Avatar
Put a wanted post up. There arn't that many variations, just give year and model of your car, and ask if anybody can supply you stock rom images.
Chances are, your only have to try a few at most before you find the correct one for your ECU/car.
Don't forget to change the imob code to the same as the one in the .hex file I sent you back.
Or if you want to shell out cash, take it to your local dealer.
  #58
jcsbanks's Avatar
You can read the label on the ECU case. If you post that up, someone will be able to tell you what ROM image to use.
Then you can either play with setting the immobiliser code to FFFF if that does indeed disable it, or you could disable it with the ECU periphery bytes (see Aktivematrix).
First you need to identify the correct ECU image to use though.
Old Jun 5, 2007 | 03:00 PM
  #59
ok guys the ECU image is 1860A118 i hope this is the rite set...If anyone has a 2005 Evo8 Stock Rom they can send me PLEASE DO
Old Jun 5, 2007 | 03:09 PM
  #60
TTP Engineering's Avatar
That number does not represent an ECU image.
