HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
Old Jun 28, 2008 | 03:05 AM
  #316
Inprogress's Avatar
http://www.radioshack.com/product/in...entPage=family
will that work? I'm doing this, im flipping sick of my car tapering to 18psi up top
Do I need to order any pills or anything on top of this?
Old Jun 28, 2008 | 09:19 AM
  #317
wshihdnevo's Avatar
yup, thats what you want. My car will be up and running in the next week or so.
Old Jun 28, 2008 | 12:14 PM
  #318
Inprogress's Avatar
Awesome!
I had 2 more questions...
Will this setup require any of those pills people use in the hose?
And how has this setup performed for people? How much have people held to redline on the stock turbo?
Thanks.
Old Jun 28, 2008 | 07:36 PM
  #319
tephra's Avatar
no pills required...
i can hold about 20psi @ redline (100% wgdc, 3" downpipe + catback, stock o2housing stock cat).
Old Jun 28, 2008 | 07:46 PM
  #320
Inprogress's Avatar
all of my boost holding a redline went down the dump after the perrin intercooler, went from about 21-22 at redine to friggin 17-18 now talk about pressure drop
Old Jun 28, 2008 | 08:40 PM
  #321
mrfred's Avatar
The Perrin ought to have less pressure drop than stock, so you should be seeing more boost. I'd be looking for a boost leak.
Old Jun 28, 2008 | 09:28 PM
  #322
Inprogress's Avatar
mrfred,
I've done nearly 3 tests and have found nothing. I don't know why my pressure is dropping so much. I hope the gm 3 port remedies it a little
Old Jun 29, 2008 | 12:18 AM
  #323
Evo8uk's Avatar
Do most people use the standard TBEC tables once they have set the BDEL and MWDC or is it simply trial and error trying to set up the TBEC table?
Old Jun 29, 2008 | 07:16 AM
  #324
mrfred's Avatar
Originally Posted by Inprogress
mrfred,
Have you tried swapping back to the stock IC?
Old Jun 29, 2008 | 11:42 AM
  #325
Inprogress's Avatar
No, it was a pain in my **** to get the Perrin in, I don't want to have to take it back out, but it may be necessary to see if that resolves it.
Thanks for the idea mrfred, I hadn't thought of that.
Old Jun 29, 2008 | 09:26 PM
  #326
Inprogress's Avatar
So what 2 wires do the pig tails off the GM 3 port connect to? The stock solenoid seemed to have multiple wires in it.
Old Jun 29, 2008 | 09:51 PM
  #327
tephra's Avatar
should only be 2 wires on the stock.
I don't think it matters which way its connected - I followed whatever is in the first post..
Old Jun 29, 2008 | 09:59 PM
  #328
Inprogress's Avatar
I see, it must have been the angle I looked at the solenoid wires then. Thanks tephra.
Old Jun 29, 2008 | 10:38 PM
  #329
wshihdnevo's Avatar
Well the red wire is power and the green is ground or return. I just finished mine up and checked the voltage today.
Old Jun 29, 2008 | 10:42 PM
  #330
Inprogress's Avatar
sweet, thanks!
