Apexi drop-in filter?
Old Jun 19, 2007 | 11:07 AM
  #31
RazorLab's Avatar
No problem, I didn't take the photo, it's from a link NJ posted earlier in the thread.
It's smaller on the filter side.
Again, I am not an engineer by any means and don't try and play one on the internet. I do know that most of the filters I have tuned for that have filter to MAF adapters have played with MAF readings while the ones that do not have that adapter, do not.
Old Jun 24, 2007 | 08:09 PM
  #32
RazorLab's Avatar
Originally Posted by razorlab
Personally I would get the Ebay as its pretty much the exact same thing as the old style BR and 1/4 of the price. The only changes to the new BR are the white filter element and rounded edges of the top piece, the base, overall design and faux velocity stack is exactly the same. I would not be suprised if both ebay and BR get them from the same supplier.
Got some photo comparisons here:
Old Jun 24, 2007 | 09:19 PM
  #33
nj1266's Avatar
Well, I for one ordered one of these ebay filter and will test it on my car when I get it. I want to see if I get any power gains with a tune.
Old Jun 24, 2007 | 09:55 PM
  #34
RazorLab's Avatar
I doubt you will see much gains on just a TBE evo 9. I saw just a handful of horsepower on a TBE evo 9 the other day and +1 psi gain from 5,500 rpm up. So the stock airbox is restrictive at that level but not much.
Interested to see the data you obtain though nj1266!
Old Jun 24, 2007 | 11:35 PM
  #35
nj1266's Avatar
The chart showed that the AFR leaned out when the filter was added. Did that trigger any knock? Should I richen the car by about 0.25 points in anticipation of a leaner mixture with the filter?
Old Jun 24, 2007 | 11:38 PM
  #36
RazorLab's Avatar
Actually in this instance it richened up. It moved to a richer load column.
I would keep an eye on your AFR either way.
Old Jun 25, 2007 | 11:25 AM
  #37
gbpkr21's Avatar
Hoepfully I am not getting off topic on you...but how do you secure the filter to keep it from moving, or do you just leave it?
Old Jun 25, 2007 | 11:27 AM
  #38
RazorLab's Avatar
You can make a L bracket out of metal, one side attaches to the bottom left bolt on the maf and the other on the frame where the stock box was. This is what BR supplies.
Old Jun 26, 2007 | 08:16 AM
  #39
rish197's Avatar
Nevermind, I found it. Thanks!
Old Jun 28, 2007 | 01:33 PM
  #40
BluEVOIX's Avatar
Where are you guys ordering this ebay filter from? I tryed searching on ebay and I cant seem to find it.
Old Jun 28, 2007 | 07:51 PM
  #41
gbpkr21's Avatar
Search for 1995-1999 Eclipse GSX filter...it will fit on an Evo.
Here you go http://cgi.ebay.com/ebaymotors/ECLIP...QQcmdZViewItem
Old Jun 28, 2007 | 08:04 PM
  #42
nj1266's Avatar
Just a heads up on my testing with this ebay filter so far. I am not done yet, because I want to make sure that my findings are as accurate as possible.
If your car is like mine with a TBE with a test pipe, then there are almost no power gains to be found. Maybe 3 hp and that could be a margin of error due to many variables that enter in street dyno logging.
Yeah, It makes a lot of fun noise and you can hear your turbo spool, but IMO it is not worth it since it will attract unwanted attention from the police.
Again, I am not done testing, but so far, it is not worth it to use this filter on lightly modded cars like mine.
I will test this filter on my friend's 05 with 272 cams and see if there are any gains. But this will have to wait until he comes back from overseas.
Old Jun 28, 2007 | 08:15 PM
  #43
RazorLab's Avatar
Your findings are inline with mine so far NJ. I should have cammed results soon as well.
I do know on higher modified cars it does indeed make a difference as my Evo gained almost 25whp where it was previously maxed out.
Old Jun 28, 2007 | 08:28 PM
  #44
nj1266's Avatar
It is amazing how close my findings are to what you posted on Norcal Evo. I saw the same richened AFR when I installed the filter. I tuned that out. I saw the same ~1 psi increase here and there and I saw the very small hp increase.
The thing that makes me uneasy about this filter is the unwanted attention that it attracts. You begin hearing the turbo spool when you hit around 3000 rpm. If you go into 4000 rpm, then you will surely attract the attention of the cops. Today, I was driving to the LA airport and I saw a lot of cops. I was really concerned that the cops could hear the car. A cop happened to pull the car right behind me over. It made my heart sink, since I thought it would be me.
After I am done with testing, I will go back to the stock filter since there are very small gains to be had with this filter on my lightly modded car.
If my car was putting 400 dynojet whp (around 350-360 on an MD), then I will put this filter on for sure.
Old Jun 28, 2007 | 08:45 PM
  #45
RazorLab's Avatar
Good to know we are seeing the same data.
I hear you on the noise. I wish I didn't have to run a open filter on my personal evo for that same reason. Some people do like the noise though.
As much as I hate to say it, for the people that want the VTA BOV sound without the VTA BOV problems, an open air filter is a good solution as it's almost hard to not hear the BOV sound with it.
