Did a few logs tonight...
Old Jul 17, 2007 | 01:17 AM
2MucHP's Avatar
Well i decided to go out and do a few logs.. I'm getting a little knock and would like to know what people think? I couldn't seem to get the wideband to connect to the laptop...
SavedDataLogs.zip
Ok this afternoon i finally got the wideband to log so i could only get one pull off so tell me what you guys think.
22 psi, 3rd gear
EvoScanDataLog_2007.07.18_16.08.17.zip
Ok went out tonight and did a couple more logs just to back up the other logs... It's real weird cause now i'm getting very very little knock..
1st log is 3rd gear 22psi, 2nd log is 1-3 just messing around 22psi
SavedDataLogs2.zip
Old Jul 17, 2007 | 08:43 AM
dudical26's Avatar
How much boost?
See if you can get the wideband to connect as that is really needed to diagnose these logs.
The timing might be a tad bit high in the spool up and mid range area's.
Old Jul 17, 2007 | 08:49 AM
fastrob691's Avatar
I would not worry about it at all.
Old Jul 17, 2007 | 09:08 AM
Pd1's Avatar
Pd1
A knock count of 3 (found in the second log) justifies, in my opinion, some work on the tune. The ECU is certainly pulling timing at this point. It's difficult to say exactly what needs to be done without knowing the AFR and boost, though. There could very well be many areas for improvement, but you've spotted one in particular in the second log.
Old Jul 17, 2007 | 10:11 AM
2MucHP's Avatar
These logs were at 22psi. i will try to get the wideband to connect and i'll post up new logs.
Old Jul 17, 2007 | 12:01 PM
chmodlf's Avatar
If you are using a serial to usb converter cable. that may be your problem with the wideband. I got one at RadioShack that works.
Old Jul 17, 2007 | 12:56 PM
2MucHP's Avatar
That's exactly what the problem was i couldnt find any drivers for the usb converter. I might have found some drivers
Old Jul 17, 2007 | 04:43 PM
2MucHP's Avatar
Bump new log with wideband in first post!
Old Jul 17, 2007 | 07:46 PM
Mellon Racing's Avatar
a little too much timing at 4500 and a little too lean at 6500 to redline, I like more fuel and timing there.
Old Jul 17, 2007 | 08:18 PM
TTP Engineering's Avatar
Tune looks fine outside of a few tenths richer at upper rpms.
Nothing wrong with the ignition timing.
Old Jul 17, 2007 | 08:25 PM
I don't tolerate mid range knock at all and you're already slightly rich at a 10.9 AFR, so if you don't want to lower boost then you're going to have to adjust the timing where it knocks.
If you're going to use that car for anything other than an occasional 3rd gear pull you're going to get more and more knock as the engine temps rise.
You're always better off pulling the timing instead of letting the ECU do it for you and it going overboard which can make the car very inconsistent.
Old Jul 17, 2007 | 08:29 PM
Attachment 109030
22 psi, 3rd gear
Attachment 109039
Small knocksums at peak torque evidences that your tune is optimized in that area. The 1's and 2's are perfect in their current form.
Old Jul 17, 2007 | 10:16 PM
RazorLab's Avatar
You guys are cracking me up.
Old Jul 17, 2007 | 10:36 PM
JohnBradley's Avatar
The knock count of 3 then rapid decay doesnt always support actual knock. If it were knock the value would have stayed the same or increased. It was probably intermittent noise and the car was already interpolating another knock filter.
Cliffs- I am with TTP on that one
I would back the fuel out, I have seen as much as a 20% load increase taking .3 AFR out (going from 11.2 to 11.5) and at 10.9 while safe its not making the best power it could.
JB
Old Jul 17, 2007 | 10:54 PM
2MucHP's Avatar
bump for backup logs... what do you guys think now?
