Did a few logs tonight...
Old Jul 20, 2007 | 08:21 PM
  #106
JohnBradley's Avatar
Originally Posted by Mellon
JohnBradley, quit putting words in mouth
I reread your post and realise now that I didnt grok what I was reading when you and Scott were having your dialog. I stand corrected and apologise, I see now that you meant to have it as a back up warning not a tuning aid specifically.
JB
Old Jul 20, 2007 | 10:13 PM
  #107
mrfred's Avatar
Originally Posted by TouringBubble
As an example, in 4th gear I'm currently at 11.0 and 12* advance @ 7000. Taking away any fuel or adding 1* of advance will bring on knock. According to Travs logs, he's at 12.2 and 14* at 7000 and has no knock (3rd gear). This is what I can't wrap my head around. Honestly, I want to think that the knock filters may have been modified but this doesn't seem to be the case.
This is exactly what I'm thinking. I'm currently running about 10* at 7000 rpm with an afr somewhere around 10-11:1 (no wideband yet), and if I lean it by 0.3, the car knocks. And this is with a slightly modded motor. The only other variable not discussed that perhaps could explain the lack of knock with travman's setup is MIVEC. Would be interesting to see his MIVEC MAP.
Old Jul 20, 2007 | 10:15 PM
  #108
mrfred's Avatar
Just as a general comment, 12:1 seems very lean to me. I were going to attempt that afr, I would approach it very cautiously starting with convervative timing and boost.
Old Jul 21, 2007 | 12:27 PM
  #109
2MucHP's Avatar
Well me and dudical26 went out last night and did some tuning. We straightened up the a/f we pulled out a good amount of fuel. Only pulling fuel netted us 6 more DLL horsepower and 9 tourqe so that is a very good start allready the car feels a lot better. We are going to play with timing next and try some things with the mivec map and see what we can do. The car was previously tuned by an unnamed "block tuner" and after seeing those logs i dont know if i will be a returning customer.
Old Jul 21, 2007 | 06:49 PM
  #110
Tuner@Swift's Avatar
I'm tuning for a 12:1 AFR as well. I did 6 consecutive pulls with a really lean spool up (13:1), lean peak load (12.5:1) and a lean run to redline (12:1). Timing @ peak torque is 4-5 and timing @ 7krpm is 13-14. I get 1-2 counts of knock sporadically. Other than that its great. Of course, the water/meth helps.
This shows the 6 consecutive runs:
This shows the 6th run up close:
Old Jul 21, 2007 | 10:16 PM
  #111
Ph3n1x's Avatar
I can't understand yout graphs... do you have .csv logs?
Old Jul 21, 2007 | 10:31 PM
  #112
Evo_Pma's Avatar
looks good dont worry about that litle knock its good
Old Jul 22, 2007 | 04:44 AM
  #113
TouringBubble's Avatar
Yeah Matt, those graphs look good. Running that lean with meth is common and proven to make power. I'm pretty sure the big debate in this thread doesn't involve meth though.
Old Jul 22, 2007 | 05:38 AM
  #114
C6C6CH3vo's Avatar
12.1 is a tad rich, really
yositoco
Apr 15, 2013 06:41 PM
blk-majik
23
Aug 16, 2012 04:20 PM
luvnish
Apr 25, 2009 01:22 AM
gosu.pianist
Feb 18, 2008 11:49 AM
fusionchicken
West Region
Sep 4, 2007 10:19 PM
