Nolift to Shift??
Old Sep 15, 2007 | 04:09 PM
  #91
4TUN8's Avatar
Any update??? I really want no lift to shift
Old Sep 15, 2007 | 07:31 PM
  #92
tephra's Avatar
yup just going through testing atm...
Old Sep 15, 2007 | 07:43 PM
  #93
joosdawg's Avatar
im headed to the track in the morning need any beta testing done lol dont think your that far but this is gonna be awesome when its done
Old Sep 15, 2007 | 08:42 PM
  #94
recompile's Avatar
Tephra, you are the best!
Let us know when you've got a patch that can be tested. I hope we can still use your CEL flash patch with this as well
Old Sep 18, 2007 | 04:40 PM
  #95
tephra's Avatar
quick update - testing is finaly going well - we had some problems with my code for a while
Eric *might* post up some screenies of logs if he has time - but apparently it works pretty well.
Yes you still get the KnockCEL + you also get my valet revlimiter.
Cheers
Dave
Old Sep 18, 2007 | 04:56 PM
  #96
l2r99gst's Avatar
First of all, BIG thanks goes to tephra for working so hard and making this happen. Great job!!!
A couple of notes... For testing purposes, I was shifting at about 6k RPM and I wasn't banging the gears...it was about .4-.5 seconds per shift. Also, I was at low boost of about 18 psi or so for testing. (Anyone who has Logworks and wants the actual log, let me know.)
Even so, the screenshots show that the throttle was 100% for the shifts. The TPS is the line at the top obviously. I know the screenshots may be a bit hard to read since I had to resize them small enough to post. But, you get the basic idea...the throttle is held to the floor during the shifts and the RPM doesn't hit the roof. It drops because of the NLTS rev limit.
The first screenshot is a 2-3 NLTS and the second is a 3-4 NLTS. The boost drops to about 8 psi during the time it took me to shift and recovers very quickly from there. So far so good.
(I know this is a bit off topic, but this 2-3 log above shows some bad throttle hang, known to be an issue on the 05s. At the end of the screenshot, I am in neutral with my foot entirely off the gas, but my RPMs (light blue line) held at 5k until I touched the clutch.)
Another note... When I was testing this a bit, I noticed that perhaps the stock flywheel on the Evo may not allow the engine to rev down quick enough, meaning that you can probably shift faster than the engine is going to reach the NLTS rev limit. If so, you still get the benefits of having an open throttle plate and keeping most of your boost. I think people with lightweight flywheels will benefit from this even more.
Eric
Attached Thumbnails Nolift to Shift??-2-3nlts.jpg   Nolift to Shift??-3-4-nlts.jpg
Old Sep 18, 2007 | 04:59 PM
  #97
joosdawg's Avatar
amazing!! i cant wait to try this out
Old Sep 18, 2007 | 07:16 PM
  #98
dudical26's Avatar
very cool, that was pretty quick nice going Tephra and the testers!!
Old Sep 18, 2007 | 07:44 PM
  #99
Nuked's Avatar
Nice work guys!
SQ
Old Sep 18, 2007 | 09:27 PM
  #100
fixem2's Avatar
My stock clutch is really not going to like me now!!
Old Sep 18, 2007 | 09:32 PM
  #101
tephra's Avatar
well theoretically there shouldn't be much impact to the driveline as the car isn't making much power when shifting... thats the whole point of NLTS.
Old Sep 18, 2007 | 09:53 PM
  #102
fixem2's Avatar
Understand that, but that means I am going to be doing more racing!! 44k on the stock clutch with multiple drag passes and autox.
Old Sep 18, 2007 | 09:55 PM
  #103
Asmodeus6's Avatar
what method did you finally decide on to actuate the NLTS limit Tehpra?
fuel / spark?
Old Sep 18, 2007 | 09:57 PM
  #104
tephra's Avatar
Fuel Cut for the time being - perhaps in the future I will go with retard timing as well (ala antilag)
Old Sep 19, 2007 | 04:01 AM
  #105
recompile's Avatar
Nice work Tephra. PM me if you need any testing on 88590015
