how-to: ECU-based direct boost control
Old Jun 11, 2009 | 08:12 PM
  #721
RoadSpike's Avatar
Originally Posted by RoadSpike
Here's my current scaling does this look correct to you?
<scaling name="psi16(5bar)" units="psi" toexpr="(x*0.3555) - 23.569" frexpr="(x + 23.569)/0.3555 " format="%.2f" min="0" max="60" inc="0.26" storagetype="uint16" endian="big"/>
<scaling name="psi8(5bar)" units="psi" toexpr="(x*0.3555) - 23.569" frexpr="(x + 23.569)/0.3555" format="%.2f" min="0" max="60" inc="0.25" storagetype="uint8" endian="little"/>
<scaling name="BoostErrorPsi(5bar)" units="psi" toexpr="((x-128)*0.088875) - 23.569" frexpr="((x+ 23.569 ) /0.088875) +128" format="%.2f" min="-10" max="10" inc="0.5" storagetype="uint16" endian="big"/>
Bump for a little love on the boosterrorpsi scaling
I'm guessing the others are correct but i really have no idea.
Old Jun 11, 2009 | 10:06 PM
  #722
rolly1818's Avatar
Registered User
are u trying to verify u got the right scalings?
if so, i can in the morning, i dont have my xmls on this pc.
Old Jun 12, 2009 | 09:42 AM
  #723
RoadSpike's Avatar
Yep but this is for a 5 bar sensor so its a little wierd
Old Jun 12, 2009 | 03:12 PM
  #724
rolly1818's Avatar
Registered User
lol i am no help then
it should really be some adjustment calculation wise IMO. where there was the psi for a 3 bar=32psi. is should be replaced with the psi rating for your map sensor.
Old Jun 12, 2009 | 11:04 PM
  #725
RoadSpike's Avatar
Well that would be nice but if the bits represent 5volts i need to figure that out first
Old Jun 15, 2009 | 01:34 PM
  #726
rolly1818's Avatar
Registered User
free bump for help
Old Jun 19, 2009 | 12:35 PM
  #727
silex's Avatar
Is there a way to do ECU controlled boost with a GM 3bar MAP sensor?
Old Jun 24, 2009 | 03:46 AM
  #728
shadow1's Avatar
Has anyone noticed that the highest value that can be entered for max WGDC is 127.5%? Does any value over 100% actually do anything more?
Old Jun 24, 2009 | 04:00 AM
  #729
tephra's Avatar
no
Old Jun 24, 2009 | 10:42 AM
  #730
GST Motorsports's Avatar
100% is the max
Old Jun 24, 2009 | 11:14 AM
  #731
shadow1's Avatar
Originally Posted by GST Motorsports
100% is the max
Common sense dictates 100% is the max but I thought it was interesting that more than 100 can be entered. Question, do most folks using mrfred's method of boost control use 100% WGDC and peak boost targets in the low rpm ranges (500-2500)? I have my set up that way with an Ingersoll-Rand 3 port solenoid and I do not have any boost spikes.
Old Jun 24, 2009 | 11:19 AM
  #732
Yup. It is 100%, anything more doesn't do anything.
Old Aug 14, 2009 | 11:59 AM
  #733
mrfred's Avatar
OMNI 4-bar compatbility added
The instructions have been updated to include the scalings needed to use an OMNI 4-bar for direct boost control.
Old Aug 14, 2009 | 01:49 PM
  #734
rolly1818's Avatar
Registered User
mfred
need your input here: i moved to SD with 88570008 - JDM rom that jscbanks made. car idles great, dries normal (AFRS look fine).
however, my max WGDC on the Alt map and main map are both set below where i should be (at 20) i should be getting 12 psi as normal, however, i am seeing 29 psi!
i tested the wastegate solenoid using evoscan and it clicks!
here are some pics of my settings:
the Alt Map:
then the Normal boost maps:
the only thing i can guess is the BDEL has more of an effect for SD????
Thanks
Old Aug 14, 2009 | 07:58 PM
  #735
EViTZO's Avatar
Thank you mrFred! Perfect timing for the omni 4 bar update... I just got mine in today ^_^
