how-to: ECU-based direct boost control
Old Sep 12, 2009 | 11:48 PM
  #871
McLaren F1 2003's Avatar
Originally Posted by krazykorean84
Sounds like its just Mclaren's preference, no?
it is...haha thank you
you guys going to complain that im running a 100 cell cat too. "why dont you just get a test pipe? i dont understand why people buy evos and dont want to deal with the test pipe smell...its amaaaazing"
ok, im done ranting, back on topic
Old Sep 15, 2009 | 12:41 AM
  #872
SeanV's Avatar
Originally Posted by mrfred
EDM cars don't have a MAP sensor or built-in wiring for a MAP sensor, so this mod is not easily accomplished with EDM cars. It would probably be pretty hard to implement.
A question or two for MrFred..
I have a 96530706 ROM on my Evo 8 and I also have a Defi MAP sensor wired into the ECU through the JDM Map sensor pin. In other words, my ECU now see's/reads boost.
My question is... actually I have two.
Does the above statement still hold, whereby it is near impossible to do ECU Direct Boost Control on non USDM cars?
Even if the ECU on the non USDM cars like mine can now see boost through the Defi boost sensor?
Assuming it can be done on my EDM ECU, will ECU Direct Boost Control work with the per gear boosting as found in Tephra's latest V7t6 mods?
Thx
Old Sep 15, 2009 | 06:42 AM
  #873
Monochrome's Avatar
Thx
I can answer these.
No that statement isn't true anymore. I'm currently running this version of boost control with the edm rom. If your sensor is wired to the same pin as the map sensor then it will work just the same.
You don't need gear based boost control with this setup (which is why I use it) since it's adjusting the pressure directly off the map sensor instead of load. In other words It'll automatically adjust for each gear and altitude. You basically just set it and forget it.
Old Sep 15, 2009 | 06:48 AM
  #874
SeanV's Avatar
Originally Posted by Monochrome
I can answer these.
Thx, exactly what I needed to hear
One more question..
I searched this thread but didn't find any information.... where do I find the instructions/patches to get ECU direct boost control for a 96530006 ROM.
Old Sep 15, 2009 | 07:02 AM
  #875
tephra's Avatar
u still need gear based boost control to set the initial base wgdc...
1st, 3rd and 5th all require VERY different WGDC curves to obtain the same boost level and TBEC doesn't react quick enough particularily in 1st and 2nd...
Old Sep 15, 2009 | 08:00 AM
  #876
the_mork's Avatar
One more question..
Search this thread for 96530006 to find it. I believe Tephra posted the information you need but it is not near the first page.
Old Sep 15, 2009 | 12:14 PM
  #877
SeanV's Avatar
Thx found it , must have had a typo the first time round when I searched.
But it looks like I will be staying with the Load/per gear boosting for now using the V7t6 Tephra mods on my 96530706 ROM.
Biggest problem I can see is that the Direct Boost control is all setup for PSI, and where I am, we make use of the metric system and measure boost in BAR. I didn't come across any posts where the definitions were changed to work in BAR.
Old Sep 15, 2009 | 12:18 PM
  #878
GST Motorsports's Avatar
I'm sure you can just change the scaling in the definition.
Old Sep 15, 2009 | 12:38 PM
  #879
the_mork's Avatar
Check the links to speed density patches thread for scaling in kpa then simply change the scaling definitions in MRfred's patch and the unit settings for the boost desired engine load table.
Old Sep 15, 2009 | 02:17 PM
  #880
kaj's Avatar
kaj
before i take a week to read all 60pgs.. is there a post with the scalings to enter for a GM 3bar??
Old Sep 15, 2009 | 02:31 PM
  #881
shadow1's Avatar
mrfred has a separate thread on the GM 3 bar. Search.
Old Sep 15, 2009 | 05:55 PM
  #882
kaj's Avatar
kaj
been searching all day. my eyes burn. but mrfred's name will help narrow it down. thank you
Old Sep 15, 2009 | 05:59 PM
  #883
EvoIan's Avatar
Wrong link sorry
Old Sep 15, 2009 | 06:01 PM
  #884
Evo_Jay's Avatar
wrong thing. Hes looking for the GM MAP info.
Old Sep 16, 2009 | 09:05 PM
  #885
mrfred's Avatar
One more question..
The challenge you'll have using the Defi sensor is that no one has worked out the correct ECUFlash direct boost control scaling values for that sensor. And without those scalings, direct boost control is impossible.
