how-to: ECU-based direct boost control
Old Sep 6, 2009 | 02:19 PM
  #841
kaj's Avatar
kaj
okay. quick questions:
will this help? :
http://www.tactrix.com/product_info.php?products_id=47
so, i can use a X map sensor. where in hell can i FIND them? i've googled everywhere and searched here.
and i need this, also, right?:
http://www.gstmotorsports.com/store/...oducts_id=1050
sorry for all the noob stuff. just trying to make sure i don't waste any time or money.
stock engine. Bushur MAF intake. 3" DP/TBE. just looking to hold boost 'till redline. maybe run a bit more, if safe.
Old Sep 6, 2009 | 04:31 PM
  #842
Evo_Jay's Avatar
will this help? :
You only need one or the other. Either you use the tactrix solenoid and NO pill, or you use the stock solenoid and a modified boost pill (like GSTs).
PM me for more help
Old Sep 7, 2009 | 07:33 AM
  #843
rolly1818's Avatar
Registered User
forget the pill, get a 3 port and boost away
Old Sep 7, 2009 | 08:11 AM
  #844
shadow1's Avatar
X map sensor is available from any dealer. Mitsubishiparts (evoM vendor) also stocks them.
Old Sep 7, 2009 | 10:34 AM
  #845
Jack_of_Trades's Avatar
+1
If you're gonna waste the time tuning your setup via the ECU...do it once and be done with it.
Old Sep 7, 2009 | 10:39 AM
  #846
rolly1818's Avatar
Registered User
+1
the funny thing is since i installed my 3 port i have been playing with my boost settings daily
Old Sep 7, 2009 | 10:57 AM
  #847
lol, I guess what I meant was....why bother going thru all of that dialing in once, then want to start all over with a 3 port down the road.
Old Sep 12, 2009 | 01:41 PM
  #848
lan_evo_mr9's Avatar
Will this mod work in conjunction with the alt maps or strictly with the "normal" map? Just wondering if you could have 2 boost control settings, one for each map.
Old Sep 12, 2009 | 01:53 PM
  #849
the_mork's Avatar
With v7 you have altmaps for boost control.
Old Sep 12, 2009 | 01:59 PM
  #850
I'm running 5.10 on 88590015. I don't think v7 is complete for my rom yet. I take that this would work only for the normal map then and not the alt map in my situation.
Old Sep 12, 2009 | 02:14 PM
  #851
McLaren F1 2003's Avatar
ill address this:
i used the upgraded gst boost pill instead of the gm 3 port because i didnt want to splice or solder anything.
this is the reason im looking forward to real testing on the grimmspeed solenoid
Old Sep 12, 2009 | 03:45 PM
  #852
rolly1818's Avatar
Registered User
on the normal map direct works as in the thread (psi based).
in the alt map (Tephra V5.10) it is the same WGDC tables as before and still works the same as previous. so no probelms caused by it.
Old Sep 12, 2009 | 03:46 PM
  #853
rolly1818's Avatar
Registered User
Originally Posted by McLaren F1 2003
ill address this:
the 3 port is simple the best, u can mount it wherever and the pigtail part of it looks neat, u dont need to splice or solder anything, its basically changing boost lines and the three port.
its worth it!
Old Sep 12, 2009 | 03:50 PM
  #854
the gm 3 port is not plug and play. you have to have to cut off the stock solenoid, and wire the gm in.
that is not something i want to do...sorry
Old Sep 12, 2009 | 04:28 PM
  #855
Monochrome's Avatar
The one I installed on my car does.
