how-to: ECU-based direct boost control
Old Dec 6, 2009 | 04:01 PM
  #931
Danieln's Avatar
<table name="Variable for Boost Control" category="BOOST CONTROL" address="408B2" type="1D" level="1" scaling="Hex16"/>
<table name="WGDC Correction update delay #1" category="BOOST CONTROL" address="1654" type="1D" level="1" scaling="uint16"/>
<table name="WGDC Correction update delay #2" category="BOOST CONTROL" address="1656" type="1D" level="1" scaling="uint16"/>
<table name="Load Error RAM Address" category="BOOST CONTROL" address="408A6" type="1D" level="1" scaling="Hex16"/>
<table name="Load Error RAM Address in Load Error Table" category="BOOST CONTROL" address="735C" type="1D" level="1" scaling="Hex16"/>
<table name="MUT8A" category="BOOST CONTROL" address="37A22" type="1D" level="2" scaling="Hex16"/>
<table name="MUT8B" category="BOOST CONTROL" address="37A26" type="1D" level="2" scaling="Hex16"/>
<table name="SHLR->SHLL for EBC" category="Turbo" address="?????" type="1D" level="1" scaling="Hex16"/>
<table name="Boost Error RAM Address" category="Turbo" address="41E06" type="1D" level="1" scaling="Hex16"/>
<table name="Boost Error RAM Address in Load Error Table" category="Turbo" address="7254" type="1D" level="1" scaling="Hex16"/>
<table name="Boost Error Correction" category="Turbo" address="3f44" type="2D" level="1" scaling="OffsetWGDC">
<table name="Boost Error" elements="17" type="Y Axis" address="7360" elements="17" scaling="BoostErrorPsi"/>
</table>
<table name="Boost Adder" category="Turbo" address="1670" type="1D" level="1" scaling="psia16"/>
<table name="Base Boost #1 (High Gear Range)" category="Turbo" address="3fa4" type="2D" level="1" scaling="psia8">
<table name="RPM" address="7336" elements="16" type="Y Axis" scaling="RPM"/>
</table>
<table name="Base Boost #3 (Low Gear Range)" category="Turbo" address="3fd6" type="2D" level="1" scaling="psia8">
</table>
Mrfred when you will find time can you please look also for the address for SHLR->SHLL for EBC at 88840017/16?
I think the rest of the definitions are correct and I just need the SHLR address for PSI direct boost control.
Thanks in advance
Last edited by Danieln; Dec 6, 2009 at 04:09 PM. Reason: change some wrong addreses
Old Dec 11, 2009 | 04:27 AM
  #932
ace33joe's Avatar
So if I use Omni 4-bar sensor and want to log "Boost Error" at the evoscan, should I change the "Eval" part to "0.02955*x-3.7825" rather than "0.0241*x-3.087", which is for JDM 3-bar sensor?
Old Feb 5, 2010 | 12:35 AM
  #933
Chris Moore's Avatar
Just curious if most of you have Map Averaging enabled or not?
Thanks
Old Mar 14, 2010 | 02:56 PM
  #934
evo8dad's Avatar
What exactly does BCS Re/De Activation RPM do? I tried searching for an answer but, didn't come up with anything. I'm trying to trouble shoot 9653 v7 direct boost control and wanted to better understand what this does. Thanks
Old Mar 15, 2010 | 07:08 AM
  #935
chmodlf's Avatar
WGDC goes to 100% when the bcs is not "active". So the RPM hits x and it deactivates the BCS. The RPMS drop below say 2100 and is off (100%) the rpms come up again to 2200 and it goes back on.
Reactiviate is low RPM threshold on and off.
Decativate is high RPM threshold on and off.
This is why it is important to set the deactivate values to above your rev limit. Mine is at 8500. Otherwise your WGDC is 100%. Bad things could happen at the top of the rev range...
Old Apr 10, 2010 | 06:06 AM
  #936
EVO8LTW's Avatar
Has anyone worked out the scalings for the 3.5 bar Zeitronix/Kavlico sensor?
Old Apr 14, 2010 | 11:16 AM
  #937
304MR's Avatar
4 bar overkill
Sorry if I didn't do this right. I'm new to this.
Is a 4 bar map sensor overkill for 23 to 24 pounds of boost on an evo 9. If it is where can I get the jdm 3 bar.
Old Apr 14, 2010 | 11:32 AM
  #938
travman's Avatar
just get the 4 bar.......its not overkill
Old Apr 14, 2010 | 12:12 PM
  #939
304MR's Avatar
Thanks, i'll just get the omni 4 bar.
Old May 3, 2010 | 08:24 AM
  #940
Ian0611's Avatar
subscribe
Old May 4, 2010 | 05:52 PM
  #941
AutoXer's Avatar
Originally Posted by nonschlont
Another thing, re-scale your rpm axis for your boost tables(WGDC/BaselineBoost), to get better resolution/control where you need it. 500/2000/2500/3000/3500/3750/4000/4250/4500/4750/5000/5500/6000/6500/7000/7500, or however you like. Since you have 100% duty cycle till 2500, you could better utilize the 1000/1500/2250/2750 cells. You will have more control over the meaty part of the powerband, rather than spool up.
Note: This is only for the "baseline boost / WGDC tables", if you were to do this w/ the timing and fuel maps, it will throw off your tune.
all you need to do is click "=/+ button, it will pop up w/ a lil screen, you input what ever value you want, then click enter.
Originally Posted by fostytou
You just enter the values you want in the left side of the table. Be aware that another function that you can't see *could* be accessing this table of RPM values and might then be thrown off.
Can someone confirm that the RPM scale is only used for boost control? I did a quick search of the ECUFlash XML for the address and found the following:
"Base Wastegate" (Main and Alt)
"Boost Desired Load" (Main and Alt)
"Boost Desired PSI" (Main and Alt)
"Min Load for Boost Control"
"Accel Enrichment (Incorrect)" This seemed odd.
<table name="Accel Enrichment (Incorrect)" category="Global Fuel Settings" address="3864" type="2D" scaling="EnrichmentAdj">
<table name="RPM" address="6982" type="Y Axis" elements="15" scaling="RPM"/>
</table>
Old Aug 22, 2010 | 08:49 PM
  #942
jtyler's Avatar
Is this only for stock EBCS or does this work with others, eg. the grimmspeed 3-port?
Old Aug 23, 2010 | 05:40 AM
  #943
mrfred's Avatar
Any 3-port provided that the circuit resistance is reasonable. The GM and Grimmspeed 3-ports are the best.
Old Aug 23, 2010 | 05:52 AM
  #944
shadow1's Avatar
Has anyone tried out the new design Perrin 3 port?
Old Aug 23, 2010 | 06:18 AM
  #945
mrfred's Avatar
Send me one and I'll try it out. :-)
