Trouble with 2-byte airflow in 96940011 ROM
Old Sep 12, 2007 | 06:37 AM
Tom-05-MR's Avatar
Hey guys,
I'm new to the whole EcuFlash thing. I bought a JDM MAP sensor from mrfred (thanks!), and I installed it last night. I made the modifications in this thread to the MAP sensor tables, and then I went to this thread for information on outputting 2-byte load, airflow, and RPM, as well as upping the baud rate to 62500. I uploaded the ROM with the modifications. The JDM MAP, load, RPM, and baud work fine, but 2-byte airflow doesn't. All I get from EvoScan is values within a few billionths of 0.09828125, which is what I'm multiplying x by in the formula (so what I'm actually reading is right around 1).
In the first row of my MUT table in EcuFlash, in column 6 I have 899A and in column A I have 899B (for 2-byte load). In column E I have 89F6 and in column 12 I have 89F7 (for 2-byte airflow). In column 16 I have 8976 and in column 1A I have 8977 (for 2-byte RPM).
In EvoScan's data.xml, I have the following rows for load, airflow, and RPM:
Code:
<DataListItem DataLog="N" Color="" Display="Load MUT 2Byte Mod" LogReference="LoadMUT2Byte" RequestID="00" RequestID2="01" Eval="0.3125*x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes=""/>
<DataListItem DataLog="N" Color="" Display="Airflow MUT 2Byte Mod" LogReference="AirflowMUT2Byte" RequestID="02" RequestID2="03" Eval="0.09828125x" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="2500" ChartMin="0" ChartMax="2500" ScalingFactor="0.1" Notes=""/>
<DataListItem DataLog="N" Color="" Display="RPM MUT 2Byte Mod" LogReference="RPMMUT2Byte" RequestID="04" RequestID2="05" Eval="1000*x/256" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8" ChartMin="0" ChartMax="80" ScalingFactor="0.01" Notes=""/>
Does anyone know what I might be doing wrong? Thanks in advance for any help.
Old Sep 13, 2007 | 07:08 AM
Tom-05-MR's Avatar
Ok, I logged in Mitsulogger instead and it worked perfectly. My lines for 2-byte airflow in Mitsulogger's requestID.xml are:
Code:
<Request LogReference="AirflowB00" RequestID="02" Eval="x" Unit="INT" Logged="y" Response="2"/>
<Request LogReference="AirflowB01" RequestID="03" Eval="x" Unit="INT" Logged="y" Response="2"/>
<Request LogReference="Airflow2Byte" RequestID="FF" Eval="6.29/64*((256*AirflowB00)+AirflowB01)" Unit="Hz" Logged="y" Response="2"/>
6.29/64 = 0.09828125, so the formulas are the same between the two programs. Since it works in Mitsulogger but not Evoscan, it's clear that everything's ok on the ECU side and I've just got a problem with the way I've configured Evoscan. I would still appreciate any insights, if anyone else has run into a similar problem.
Old Sep 17, 2007 | 12:48 PM
Tom-05-MR's Avatar
I'm sorry to bump my own thread again, but I worked at this all weekend and I can't figure out why Mitsulogger is logging 2-byte airflow properly but Evoscan isn't. Is there an Evoscan-specific support forum somewhere that I should take this to?
Old Sep 17, 2007 | 04:03 PM
mrfred's Avatar
Originally Posted by Tom-05-MR
Hey guys,
Code:
The scaling factor in the EvoScan airflow definition is 0.1. Would you rather use a value of 1? Also, just for kicks, it might be good to switch 0.09828125x to 0.09828125*x.
Old Sep 17, 2007 | 05:33 PM
Tom-05-MR's Avatar
Thanks mrfred! The missing * was the problem. I feel bad about it being something so simple. I stole the formula directly out of this post. I didn't changed the scaling factor from 0.1 to 1; I don't actually understand what scaling factor is yet but I'll experiment with it tomorrow.
Old Sep 17, 2007 | 06:43 PM
mrfred's Avatar
Yeah, the new version of EvoScan coming out soon is supposed to fix the unpredicatable acceptance of math symbols in formulas. I think the scaling factor is for the gauges and data plotting. Have fun. :-)
Old Sep 18, 2007 | 03:07 AM
ThEHiTMaN's Avatar
Would one be able to figure boost based on HZ if the damn thing wasn't pegged at 1603Hz. lol I have been trying to find a 2-byte airflow for 70008 but can't.
Old Sep 18, 2007 | 06:21 AM
Tom-05-MR's Avatar
I can't answer your question about figuring out boost, but I can tell you that this thread tells you how to set up 2-byte airflow on the 70008. Post #7 notes the memory locations. If that's not enough info, I can probably give you specific directions.
GST Motorsports
113
Feb 14, 2017 06:09 AM
Deepnine
Jul 8, 2009 05:02 AM
recompile
Apr 2, 2008 10:59 PM
JohnBradley
Dec 9, 2007 07:55 AM
TouringBubble
Apr 20, 2007 08:18 AM
