Cant Flash or Read ECU.
Old Dec 22, 2007 | 03:02 PM
ohhgyeahfasho's Avatar
i am again having this problem with my other friend's car. i believe its the battery. will getting the battery recharged work? we tried the jumping cable, but i guess we did it wrong because it didn't work at all..haha
Old Dec 22, 2007 | 03:30 PM
codymac's Avatar
As others have already said - hook up a strong battery charger and put it on the high setting. Also be sure to turn off anything using power (stereo, amps, EBC, TT, etc.).
I'm not a fan of the jumper cable or running car solution, myself.
Old Dec 22, 2007 | 06:28 PM
h.funk's Avatar
Is the ecu unlock a must have to flash??
Old Dec 22, 2007 | 06:39 PM
fugiwara's Avatar
I just had this problem couple months ago, haha, it's easy, if it's not the battery, or the laptop problem, then it's the tactrix cable itself. I got a new replacement from tactrix and it solved the problem. Trust me on this one, i was so frustrated, and I used my buddy's laptop, try to reflash differ evo, both 8 and 9 and install differ version and I finally narrow it down.
Old Dec 22, 2007 | 06:46 PM
yes, the cable could be the problem. but in my case, it is not. my cable works with my car flawlessly, and works with over 20 other evo's that i have used it on..it only doesn't work with 2 of my friend's evos..so i know it isnt the cable..so it must be the battery...
Old Dec 23, 2007 | 07:51 AM
codymac's Avatar
Only if the ECU has been "locked" by a previous flash.
Old Dec 29, 2007 | 02:50 PM
charging the battery at autozone for free did the trick for us..
Hollywood_Evo
Nov 8, 2011 06:22 AM
rolly1818
Nov 25, 2008 05:09 AM
rolly1818
Nov 15, 2008 06:58 PM
Slo_crx1
Apr 21, 2008 12:39 PM
mexevo
Sep 10, 2007 07:46 AM
