PATCH: NLTS + Valet + KnockCEL
Old Nov 8, 2007 | 05:26 PM
  #796
tephra's Avatar
Originally Posted by BarryC
no problem Dave thanks Mate
round 5 - *crosses fingers*
Originally Posted by Adamantium
88570008 - can confirm that flashing CEL works as does valet mode, but can't say the same for NLTS.
Only tried it once and revs just climbed, that said, I didn't install it myself and until I get a laptop on there, I can't know if he actually enabled the nlts.
2/3 definitely, 1 maybe.
Hrmm do you have a cable you can test it out with yourself?
Normally for NLTS testing I recommend a low TPS (20%) and then just rev the car in the driveway and push the clutch... rpms should drop
Cheers
D.
Old Nov 9, 2007 | 03:36 AM
  #797
Adamantium's Avatar
will try that in the future.
Haven't had a chance to do that as it is currently set at 95%.
I did have a nother yesterday. pedal to the floor (hope that is 100%) and dipping the clutch sent the revs flying up.
I did this at about 5k rpm at around 50mph, as 5k gave me reaction time to prevent it slamming hard into the limiter.
will change the settings and try again without the speed limit to see what happens.
Everything else works a treat.
Still happy to send donation if you tell me how to!
Old Nov 9, 2007 | 03:38 AM
  #798
tephra's Avatar
just paypal to donations@globalshare.net
um do you have your clutch switch disconnected?
if you like email me your ROM and I will dbl check ive done it right
Old Nov 9, 2007 | 09:55 AM
  #799
xtremeIX's Avatar
Quick question, when the car is in valet mode is the CEL light supposed to flash? I would think this shouldn't happen so the valet people didn't think something was wrong with your car.
Old Nov 9, 2007 | 09:59 AM
  #800
Jack_of_Trades's Avatar
Yes its supposed to flash. If they think something is already wrong with the car...they'd be less inclined to mess with it anyways.
Old Nov 9, 2007 | 05:47 PM
  #801
tephra's Avatar
yup - although the next version will have a timer you can specify...
Old Nov 10, 2007 | 05:12 PM
  #802
xtremeIX's Avatar
I installed the Tephra modifications and everything works perfectly. I set the RPM drop to 1000 rpm and went out for a test drive; still had unsmooth shifting. Does anybody know why I still get a small clunk. I noticed the rpms don't even drop 1000 rpm before I'm in the next gear. If I let them drop all the way down would the shift be smoother? I have a 5 speed transmission. I am letting the clutch all the way out...
Old Nov 10, 2007 | 05:30 PM
  #803
chaz517's Avatar
are you hearing the machine gun sound between shifts?
Old Nov 10, 2007 | 05:36 PM
  #804
The hard clunk coming from the rear diff?
Old Nov 10, 2007 | 06:42 PM
  #805
xtremeIX's Avatar
It's definitely not a machine gun sound. My only guess is the stock clutch has a hard time grabbing...sound possible?
Old Nov 10, 2007 | 08:59 PM
  #806
The most common noise people get when hard shifting is the rear diff getting slammed (into the bottom of the car?) and making one solid whack between shifts. I will get this on occasion going from 1-2 but its generally my fault from being too aggressive. I haven't had that noise happen with the NLTS mod though.
Old Nov 10, 2007 | 09:06 PM
  #807
Asmodeus6's Avatar
That sh** stops permanently when you do the RMB and rear diff poly bushings.
Drive it like you stole it.
Old Nov 10, 2007 | 09:29 PM
  #808
diablo2184's Avatar
i tried to download and it didnt work.....what am i doing wrong? it seemed like the server that the files are on were down or something
Old Nov 10, 2007 | 10:14 PM
  #809
cfdfireman1's Avatar
not down now
Old Nov 11, 2007 | 04:07 AM
  #810
kjewer1's Avatar
I found that at the recomended 1500 rpm I get no rear end clunk, and at just about anything less than that, I do. If you are hearing the machine gun sound, or the actual rev limiter limiting, you're ****ing too slow to need this mod anyway. In all fairness though, it's somewhat normal to get one pop on the 2-3 shift, but I haven't verified this on this particular setup.
