PATCH: NLTS + Valet + KnockCEL
Old Dec 30, 2007 | 10:25 PM
  #946
Profoxcg's Avatar
Originally Posted by tephra
can you email me the ROM that you flashed?
the one that would let you do the NLTS with the speed set to 30km/h and the car not moving?
tephra a.t. gmail
e-mailed you
Old Jan 1, 2008 | 02:40 PM
  #947
EVO8LTW's Avatar
96420008 says "untested" on the first post, but I just installed it and all 3 features work fine with no issues on my 04 RS. PayPal sent! Thanks, Tephra!
Old Jan 3, 2008 | 01:19 PM
  #948
Profoxcg's Avatar
tephra did you get my e-mail with the ROM and XML ?
Old Jan 3, 2008 | 04:25 PM
  #949
tephra's Avatar
sure did - just been busy - will try and get to it soon
Old Jan 3, 2008 | 10:01 PM
  #950
Profoxcg's Avatar
Thanks, Id love to get it working right. - I would really like a switch to turn it on and off on the fly - someone mentioned a physical switch on the actualy clutch sensor, what do you think of this?
what I would like to do is:
drive the car normal w no NLTS and whenever I want I would like to be able to toggle preset setting such as [Speed=25Mph] [TPS=45%][RPM drop=650] via a button on my console or something... can this be done?
Old Jan 4, 2008 | 03:11 AM
  #951
awadkhan's Avatar
no luck fer us JDM..... 93660005??.....
Old Jan 4, 2008 | 11:05 AM
  #952
rallykid's Avatar
Why do you guys need NLTS @ less than maybe full throttle?
Shouldn't NLTS be used only when "making runs", racing, whatever? In that case you would have your foot to the floor at which point NLTS would turn "on" if set to at least 95% TPS.
My only issue is that currently it is TPS based, and I like to rev match all my down shifts (even on the street, its just easier on the drive train) and the TPS based NLTS turns "on", even though I have it set to 98% throttle.
Once Tephra releases the Load Based NLTS for US versions I'll be set, can't wait.
No need to turn it "off" and "on", just leave it "on" and set it to a high enough load where it wont turn on under standard "everyday" driving. Once you area actually on it full throttle, it will start working.
Old Jan 4, 2008 | 11:09 AM
  #953
TeStUdO's Avatar
It's already out:
https://www.evolutionm.net/forums/sh...d.php?t=313893
Old Jan 4, 2008 | 12:51 PM
  #954
Profoxcg's Avatar
Why do you guys need NLTS @ less than maybe full throttle?...
nope, because at 50% TPS accel is already pretty aggresive....
and different people drive their cars differently I think load based would be awesome... but then again how do you knew you are hitting the spec load?
Old Jan 4, 2008 | 04:08 PM
  #955
rallykid's Avatar
Originally Posted by TeStUdO
That is not for US Evos, it is for Evos with an intercooler sprayer.
Old Jan 4, 2008 | 04:10 PM
  #956
Ph3n1x's Avatar
Hey, how about the updated Knock light for 900640011?
Old Jan 4, 2008 | 04:18 PM
  #957
mrfred's Avatar
The patches are for USDM Evos. 94170008 and 94170015 are both '03 USDM Evo 8s.
Old Jan 4, 2008 | 10:23 PM
  #958
Profoxcg's Avatar
tephra..
what exactly is ECuload? - for example I know RPMS is the revolutions of the engine crank per min...
Old Jan 4, 2008 | 11:31 PM
  #959
mrfred's Avatar
Engine load is a measure of the air flow entering the engine per rpm. ECUload is the engine load calculated by the ECU.
Old Jan 5, 2008 | 10:45 AM
  #960
Profoxcg's Avatar
ok, so then 100 means MAP and then anything above that is turbo (boosting)
anything before 100 mean vaccum NA / spool ?
if so then the higher the gear I am in the higher the load cells I will hit because of the speed and I am traveling at and thus more air enters?
what happens in a dyno then?
