PATCH: NLTS + Valet + KnockCEL
Old Feb 28, 2008 | 09:32 AM
  #1006
TeStUdO's Avatar
Originally Posted by KillaItalian904
Tephra, are there any differences in the NLTS in this patch versus you newer one with ALTmap. I am asking because i installed this patch months ago and ive been doing it great, but as soon as i upgraded its not acting the same. When i put the cluth in under full throttle it pops real loud like its hitting a rev limiter than after that first pop it gets past it and goes all the way to my actual rev limiter.... its like its trying to do the NLTS but then failing when i switch back to this older patch it works fine
The new NLTS/ALT MAP patch uses a load threshhold, it's not TPS based. Maybe that's the difference you're having.
Old Feb 28, 2008 | 10:40 AM
  #1007
SuPeRNeT's Avatar
Is the New patch out?
Old Feb 28, 2008 | 10:43 AM
  #1008
TeStUdO's Avatar
I was referring to V4, which has been out for awhile.
https://www.evolutionm.net/forums/sh...d.php?t=313893
Old Feb 28, 2008 | 12:38 PM
  #1009
KillaItalian904's Avatar
Thanks, changing the load constraint worked. The NLTS now works great! thanks tephra... i was doing this on the v4.0 patch which is out by the way and its awesome
Old Feb 28, 2008 | 01:01 PM
  #1010
tephra's Avatar
yeah its both load and tps based...
what did you have your load set to?
Old Feb 28, 2008 | 01:04 PM
  #1011
Evoryder's Avatar
Jamie...hook me up with one of your harnesses. I have time to do the patch and run the car!
Old Feb 28, 2008 | 01:40 PM
  #1012
l2r99gst's Avatar
Tephra,
Since 96940011 is giving you a lot of trouble for v5, can us 96940011 people at least have the latest and greatest features like load based NLTS, etc? I tested your original patch for 96940011 and it works great, but I think the load based NLTS will work even better in certain situations.
Eric
Old Feb 28, 2008 | 02:42 PM
  #1013
Jack_of_Trades's Avatar
Just click the link below in my Sig and scroll down the page a little. You can get the harness' there
Old Feb 28, 2008 | 05:11 PM
  #1014
Evoryder's Avatar
paid.
Old Feb 28, 2008 | 05:18 PM
  #1015
Cool Beans, I'm making one for Hamish so I'll just add yours to the list tonight :-)
Old Feb 28, 2008 | 05:29 PM
  #1016
cossie1's Avatar
Jack of Trades, I used your diagram to make a loom up for my E6 using an E7 ecu, but when I made it up, there was no 5 volt 1-watt Zener Diode in the diagram.
I have noticed that you've added it in now, so as everything is working fine for me at the moment, do I need to go and get a 5 volt 1-watt Zener Diode and add it into the loom ?
Also notice the 10k ohm 1/8 watt Resistor, this again is something I haven't got connected, and doing a quick search over here, seems it's not too easy to get hold of either
Are there any other values that would do the trick if there needed ??
Old Feb 28, 2008 | 06:05 PM
  #1017
Nah, you should be fine with the initial diagram. The only difference is the voltage RANGE you may experience with the basic resistor layout I had originally used without the Zener diode. The zener diode helps to limit the voltage fluctuations a LOT better.
With the resistor layout, its possible to vary from around 3.9-5 volts depending on the battery voltage (i.e; car off or car running, faulty alternator, etc..)
With the zener diode layout, you'll see the voltage anly vary from around 4.7-5 volts.
I'm actually going to be updating that diagram once more and replacing the 5.1 volt Zener diode with a 4.7 volt zener diode. Tephra would feel more comfortable not having the voltage POSSIBLY exceed 5 volts by too much inot the ADC input. Mainly as a precaution. Can't ever be too safe :-)
The ADC input has an adjustable switching point from 0 to 5 volts (its an 8bit input so we adjust it in decimal values instead of voltage values from 0-255). If you set it to anything below 2.7 volts (a setting of around 138) the ECU has trouble determining if its actually SIGNAL its seeing or just line noise. So as long as your giving it between 2.7-5.0 volts you have a nice strong signal.
You obviously have to set the switching point LOWER than your actual voltage on your ADC input wire. Say you Never see a voltage lower than 4.6 volts, I'd set the switching point to 4.0 volts (a setting of around 205) just to give myself a little room for error.
Hope that helps anyone understand how it works a little better :-)
Old Feb 29, 2008 | 04:14 AM
  #1018
cossie1's Avatar
Thanks for that, I left mine as it was originally set, 3.01v
So far it's switched on and off when I have wanted it to.
Old Feb 29, 2008 | 11:58 AM
  #1019
rallykid's Avatar
Tephra, any idea when you will release the NLTS + Valet + KnockCEL with Load based NLTS instead of RPM?
Old Feb 29, 2008 | 12:02 PM
  #1020
TeStUdO's Avatar
It is load and TPS based. You adjust the RPM drop.
