PATCH: NLTS + Valet + KnockCEL
Old Mar 2, 2008 | 11:04 PM
  #1021
80210's Avatar
Thank you so much! Will this work on the latest versions of ecu flash?
Old Mar 3, 2008 | 03:08 PM
  #1022
Jack_of_Trades's Avatar
Yes it will.
Old Mar 4, 2008 | 01:42 PM
  #1023
rallykid's Avatar
Originally Posted by TeStUdO
It is load and TPS based. You adjust the RPM drop.
Since when? V2 is TPS based.
Old Mar 4, 2008 | 02:40 PM
  #1024
Since V4 at least.
Old Mar 5, 2008 | 04:58 AM
  #1025
TeStUdO's Avatar
I was referring to V4, which has been out for awhile.
https://www.evolutionm.net/forums/sh...d.php?t=313893
I posted this about 4 posts above when I answered your 1st question
Old Mar 5, 2008 | 09:21 AM
  #1026
rallykid's Avatar
My question was, when the NLTS + Valet + KnockCEL patch will be release with a Load based setting not TPS setting for NLTS.
You answer is above, but refers to the V4 Alt map path for cars with intercooler spray. Doesn't make sense. This is a "PATCH: NLTS + Valet + KnockCEL" post.
Old Mar 5, 2008 | 04:05 PM
  #1027
tephra's Avatar
Never
V5 will be the next version, I wont be going back to old versions to add new features
Cheers
Dave
Old Mar 5, 2008 | 04:18 PM
  #1028
Evoryder's Avatar
can't wait to test out the switch w/ new patch
Old Mar 8, 2008 | 04:24 PM
  #1029
Evoryder's Avatar
Received my kit yesterday...nice. What's the word on the diodes? I totally forgot to get you prices on them. Which ones did you need again...i don't believe i saw a diode installed on my kit.
- Jeff
Old Mar 8, 2008 | 05:29 PM
  #1030
All of the new harness' already have the 4.7V zener diode Of course you can't "see" any components, its all concealed and secured I gotta update the diagrams this weekend about that.
Old Mar 8, 2008 | 09:17 PM
  #1031
Evoryder's Avatar
oh ok..i can feel it.
Old Mar 9, 2008 | 12:21 PM
  #1032
Evoryder's Avatar
in your info sheet you provide you ask that we set the switching point to "204"? It comes default at 4.69volts..
Old Mar 9, 2008 | 10:09 PM
  #1033
Evoryder's Avatar
installed switch and loaded up new patch...doesn't switch maps.
Old Mar 9, 2008 | 10:28 PM
  #1034
Ahh, he changed the table to show volts. It used to be in 1 byte increments with the beta versions I had so I changed my tables to volts myself. Set it to 4.0 volts and recheck.
Old Mar 9, 2008 | 11:38 PM
  #1035
80210's Avatar
So is the kit for the DIY alt-map harness updated? Great info on Jamie's link, just unsure if its updated? Going to try to construct one this wknd. Thanks!
